Emissions
Old Mar 20, 2007 | 05:31 PM
Sly_Z_28's Avatar
Emissions
Hey guys,
I failed emisions!!! They said i was running too rich. How can i fix the problem? Get a tune? i dont drive the car anymore beacuse i have a bike so im not looking to go faster, i just want my car to be legal....
Old Mar 20, 2007 | 05:43 PM
matLT1's Avatar
How old are your 02's? Do you have any exhaust leaks? When was your last tuneup? I would check these things first.
Old Mar 20, 2007 | 05:49 PM
Sly_Z_28's Avatar
hmmm... my car has 62000, i dont know about my O2 sensors....i have a BORLA exhaust, i dont think i have an exhaust leak....
Old Mar 20, 2007 | 06:58 PM
94_PatriotRed_Z's Avatar
Try new O2 sensors, if that doesnt work try a new cat. I would try those 2 things in that order. Also I believe if you let the car warm up, like go for a 15min drive before you go get it inspected should help lower the smog count, because more particles will burn off in the cat
Old Mar 20, 2007 | 07:12 PM
T/A-Bob's Avatar
When does your current emissions certification expire? Maybe you don't even need to worry any more about passing emissions in IL with your car...
http://www.illinois.gov/PressRelease...29&RecNum=5675
Old Mar 20, 2007 | 07:31 PM
Sly_Z_28's Avatar
my cat is only a year old...so if they dont have the $ to run the dyno's...could i just take it in, thats the only way they knew that it couldnt pass. thanks
Old Mar 20, 2007 | 07:33 PM
Sly_Z_28's Avatar
it expired like last october or something and the car has been sitting in garage.
Old Mar 22, 2007 | 02:55 PM
AlfredB18's Avatar
I guess you were high on HC's....
My Ranger recently failed, but it had a bad coil pack on the exhaust side (8 spark plug 4 cylinder, FTW...) and the unburned fuel ruined the cat convertor as well.
That was better than the shop telling me the failed coil fudged a cylinder and I needed a new engine soon.
Try the tune-up and check all the ignition stuff out first.
Old Mar 24, 2007 | 12:11 AM
canuck94z28's Avatar
Running rich
A cat.convertor not working properly will make it run rich,and also check to make sure your knock sensor,s wire is hooked up b/c if not car runs rich and you could be getting 15 degrees of KR.Goes w/o saying but all emissions working/hooked up make a big difference! Here are some of my readings(24ppm)for H.C(JULY03)and 0.10 forC.O .My results from JULY/04 were 18ppm H.C and 0.00 C.O so i,m living proof that you can be CLEAN/MEAN and GREEN.Also make sure air filter is clean /new,pcv is new,egr is working.
sleeperZ96BT
Sep 9, 2015 08:28 AM
sherwinZ28
11
Aug 15, 2015 05:38 PM
FredM
Exhaust System
Feb 18, 2015 05:37 AM
jgeorger
Oct 24, 2002 09:31 PM
jgeorger
New England Area
15
Sep 8, 2002 09:50 AM
