A/C problems in '93Z
Old Mar 8, 2007 | 12:52 AM
zero231's Avatar
Arrow A/C problems in '93Z
I've got a '93 Z28 that has a problem with the air conditioning system. The problem is, that when I try to turn it on the compressor never kicks in and the air coming through the dash is basically vented air...If I remove the relay for the a/c compressor under the hood and jump the B1 and B4 connectors with a piece of wire, it comes on and blows cold. I've added a couple cans (approx 25oz) of r134a refridgerant with stop leak to the system with a cheapo walmart recharge kit, and yet the damn a/c compressor refuses to turn on unless the relay is removed+jumped...
so how much refridgerant does the system hold (in ounces?)?
how do i fix this problem? (without spending $600-900 for some radiator shop to replace everything)
Thanks.
Old Mar 8, 2007 | 06:55 AM
Asylist's Avatar
ummm......replace the relay?
HectorM52
Jun 23, 2016 08:42 PM
alphaauto
Feb 5, 2015 05:25 PM
Duke
Sep 3, 2002 02:48 PM
IROC5.7TPI
Aug 13, 2002 01:29 PM
454Corvair
Aug 10, 2002 07:02 AM
