Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
new member with a new question
Old Feb 23, 2007 | 11:12 AM
king_z28's Avatar
hi there ...
as u guys see from the title am new here and i finally found the place that i can ask in ...
i have a probelm with ma car , i have camaro z28 96, and i havent used it 4 more than 6 months because i have another car so, yesterday i tried 2 start it but i couldn't and i think the problem is in the fuel pump which needs priming but i don't know the lines and i dont' have the manual so i can trace lines with . so, if any one can help me i'll be thankfull ..
plz help and remember this is ma first thread .....
Old Feb 23, 2007 | 11:23 AM
Welcome to CamaroZ28.com!!!
You need to see if the fuel pump is supplying the required pressure. A rough test is to press in the valve core of the Schrader valve on the line at the rear of the passenger side fuel rail. If there's pressure, fuel will spray out when you press the valve core in (use a cloth, and don't spray fuel on a hot engine). A more accurate way to determine the health of the fuel system is to use a fuel pressure "test gauge", connected to that same location.
At idle, with the vacuum compensation line removed from the fuel pressure regulator, you want to see 41-47psi. Reconnect the vacuum line, and pressure should drop proportional to intake manifold vacuum, or about 6-8psi drop in pressure with a stock cam. Since it won't start, simply turn the key on, and look for 40psi on the gauge.
Have you scanned the PCM for codes?
Shoebox has a treasure trove of info on the LT1 cars:
http://shbox.com/1/4th_gen_tech1.html
And you would find this photo of the fuel system components mentioned in my response:
Old Feb 23, 2007 | 07:22 PM
king_z28's Avatar
thanx alot i'll check ......
Old Mar 8, 2007 | 03:18 AM
king_z28's Avatar
just a little info will help me what are the PCM codes ?
Old Mar 8, 2007 | 06:40 AM
rskrause's Avatar
Moderator
Hooking up to the OBD II connector with some sort of a scanner and seeing if the cars "computer" (usually referred to as a PCM on GM cars) is storing any codes.
Rich
Old Mar 8, 2007 | 11:30 AM
2000GTP's Avatar
PCM codes is just another term for diagnostic trouble codes which identify specific faults with the different automotive systems.
LeftoverChinese
Jan 14, 2024 03:03 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
capebuf
Jan 13, 2015 07:22 PM
Injuneer
Dec 15, 2014 09:36 AM
Brent94Z
Mar 21, 2002 04:44 PM
