Need help, Tips motor mount install>>
Old Feb 11, 2007 | 04:17 PM
mattbailey's Avatar
Well I'm stuck. I got the passanger side poly motor mount in, took about 2 hours. Hooker LT slide right in, perfect fit. Drivers side motor mount came out real easy, just like the passanger. This is where the fun starts. I'm by myself, so managing the jack is tricky, but I like about 1/4 inch to get the 18mm bolt back through the hole. I'm using prybars, jacking the motor up, even loosened the passanger side mount. No luck. What else should I try? I have to have my car before I go to work Monday night. HELP
__________________
Old Feb 12, 2007 | 09:01 AM
AL SS590 M6's Avatar
Moderator
Loosen up the motor stands where they bolt to the K-member and the mounts where they bolt to the motor. Put the big bolts thru then tighten the mounts to the motor then let the motor settle and tighten the stand to K-member bolts.
Old Feb 12, 2007 | 03:32 PM
mattbailey's Avatar
Thanks I'll try that.
HectorM52
Jul 30, 2017 11:46 AM
Jun 6, 2015 08:27 AM
4586
Parts Wanted
Mar 17, 2015 11:24 PM
alex5366
Exhaust System
Feb 24, 2015 09:12 AM
99TransAmWS6
Feb 12, 2015 07:23 PM
