View Poll Results: Built 4L60E or TH350
Built 4L60E
15
83.33%
TH350
16.67%
Voters: 18. You may not vote on this poll
Built 4l60e or TH350
Old Feb 11, 2007 | 12:39 PM
TravisA's Avatar
Car is a 94 Z28 that will see some street time and a lot of track time. Which would you guys prefer to run?
I like the OD on the 4l60e and I like the first gear in the 4l60e vs a TH350....but a th350 is a lot cheaper to build.
Old Feb 11, 2007 | 06:07 PM
12SCNDZ's Avatar
Remember a 4L60E has a better first gear ratio (3.08), and retains O/D. Our 4L60E can handle as much power as any TH350 out there.
Other than the intial cost, there's NO reason to swap to a TH350.
The kit to make a 350 work in a 4th gen, plus the cost of a good rebuild is only a few $ less than a properly built 4L60E.
With a Th350, your 60ft. times will suffer, and the money you saved will be eaten up at the gas pump because of the lack of O/D..
Frank
CPT
Old Feb 11, 2007 | 09:38 PM
Pro Built Automatics's Avatar
I agree with Frank, the 4L60E can take similar HP numbers & live. What torque converter are you planning on using with the Procharger? How much added HP with the Procharger? What rear end gear ratio are you going to use? Any information that you can give will help determine what will work best here?
Old Feb 11, 2007 | 09:42 PM
mdacton's Avatar
I would keep the 4L60 as stated it can't be built to handle whatever you want plus you get a hi 1st gear and overdrive
Old Feb 18, 2007 | 08:48 PM
camarolvr69's Avatar
th350 is lighter, doesnt soak up as much power and is way cheaper to build for any amount of power. If you built one you could change out first gear and get a big stall and still be cheaper than the 4l60e. the only reason i would vote for 4l60e is if it was your daily driver, or if you drive on the highway alot.
Old Feb 19, 2007 | 01:15 AM
Z-RATED94's Avatar
No offense, but that's your opinion. Many others would dissagree. If properly built, the 4l60e can handle anything that a 350 can. On top of that if your thinking a 350 is stronger and is what you need for better ETs I would take it you will have a very high stall rating with your converter. Not very street friendly. So why not have your cake and eat it too. I plan on uping my Vig. 2800 to a Yank 3600. I would even try a 4000, but I plan on running a 100 RWHP shot of nitrous in the future and don't want to run out of gear before the finish. Again, no offense, but I can't fathom what the RPM's would be on the highway with out the lookup coverter.
Old Feb 19, 2007 | 03:26 PM
lol the rpms would be rediculous..like 4000 rpm @ 55 mph. That wasnt my point though. i stated that unless it was your daily driver the th350 would be better. The th350 has a huge aftermarket (shifters, rebuild kits, auto/manual valve bodies) etc. The 4l60e is heavier and soaks up more power (and more expensive).
Old Feb 21, 2007 | 03:46 AM
rskrause's Avatar
Moderator
Unless it never sees the street, get the 4L60. If it's super hi-po, get a TH400. But I fail to see the benefit of the TH350 over the 4L60 and giving up OD is huge on a street car. How much cheaper is it to biuld a TH350 than a 4L60? Using the same quality parts I can't imagine it's much less expensive?
Rich
Old Feb 21, 2007 | 08:47 AM
mdacton's Avatar
Rich
I just built a 350, any performance trans cost about the same ....clutches were $200 by them self, and that was for a cheaper alto red...couldn't afford the hi dollar ones
A 4l60 can be built stronger...ask CPT, most upgrade parts for a 350 come right out of a 4l60/700 type trans I only went with the 350 cause I happened to have one on the shelf and I have a low h.p. car....plus I had a cheeta valve body and converter sitting in my shop and a 6 sp. before. Also if I descide to upgrade later I can swap a PG
another really big issue with a low h.p. car or anything under 5-600h.p. is that first gear, a 2.75 gear set is going to run you $400 for a cheap one 4l60 has a 3.06 and that helps alot to move a big ol boat
Parts Wanted
May 1, 2016 10:25 AM
blac94Z
Nov 4, 2015 01:59 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
football4life
Oct 4, 2015 07:48 AM
SEOJustin
Sep 24, 2015 04:39 PM
