12bolt From A Truck?
Old Jan 30, 2007 | 10:39 PM
Jun10rp's Avatar
Question 12bolt From A Truck?
Will a 12bolt from a chevy truck work on my car, I had a guy try to sell me one 2nite and he said it would work but I have no idea when it comes to rear ends
Old Jan 30, 2007 | 11:23 PM
You would have to:
-check the width to see if it is correct, and have it narrowed if its too wide.
-fabricate a mount for the torque arm
-modify the housing ends to accept the disc brakes and e-brake
-strip all mounting brackets, and weld on your old stock brackets for the shocks, springs, panhard rod and LCA's.
-check to see if the 12-bolt has a posi
-check to see if the 12-bolt has the gear ratio you want
-check to see if the diff needs to be rebuilt.
Its been done, but it takes a lot of work, and a lot of money. And a "truck" 12-bolt is not the same as a "car" 12-bolt, and requires different parts than a rear obtained from a car. The truck 12-bolt has a 1.438" pinion, compared to the 1.625" pinion in the passenger car 12-bolt, for example.
Old Jan 30, 2007 | 11:57 PM
Jun10rp's Avatar
is it better than the car rear end
Old Jan 31, 2007 | 07:20 AM
95LT1conv's Avatar
i think what Injuneer is actually trying to tell you is, the money and time spent converting a truck rear is better spent on a rear desighned for you car.
Old Jan 31, 2007 | 08:19 AM
Javier97Z28's Avatar
Moderator
Did you just skip Injuneer's post alltogether?
Do you have fabrication skills? Do you have a welder....
Don't think you'd be asking this if ya did...
Old Jan 31, 2007 | 11:49 AM
Jun10rp's Avatar
yes i have skills i have a we;der i was askin if it is better cause he said it has been done so why did they do it because its better or cheaper, maybe you didnt understand what i said
Old Jan 31, 2007 | 09:38 PM
When I said "its been done", I meant someone went to all that trouble to put a CAR 12-bolt in his 4th Gen. After he got all done, I think he saved about $500 off of what he would have spent for a Strange or Moser 12-bolt. He did all the work, including the welding himself, including building a jig. He said he would never do it again, because the work he put into was not worth the $$$ he saved.
I was not indicating that anyone I know has converted a TRUCK 12-bolt. Sorry if I mislead you.
kandied91z
Sep 30, 2015 11:43 PM
jackpawt883
Sep 10, 2015 08:53 PM
Aug 24, 2015 06:41 AM
Aug 7, 2015 08:52 AM
Collinjacobfowl
Jul 30, 2015 09:35 PM
