Rear End Removal
Old Jan 23, 2007 | 05:39 PM
eagleknight97's Avatar
Rear End Removal
Are there any step by step tutorials on the web for this? Also, is it possible to do without the car being on a lift? I would like to POR-15 the underside of my car this summer and also the rear axle and figure it would be much easier and I could get better coverage with the rear axle out of the way. I would also be slapping on a rear end girdle while its out. Which also begs the question, what is involved in putting a new rear end cover on and are there any tutorials on that also. Thank you
Old Jan 23, 2007 | 06:06 PM
Bayer-Z28's Avatar
as far as removing the rear itself...It's just disconnecting anything holding it in.
Disconnect and/or remove:
-TQ Arm
-Driveshatft
-LCA's
-PHB
-Sway Bar connections
-Shox
-Brake HYD lines
-Ebrake connection.
-ABS wheel speed sensors
You may be able to unbolt the brake line connection from the body and then remove the calipers to eliminate braking the HYD system loose.
Are you looking for help for a regular rear end cover install? or a TA girdle install?
TA cover install...Install has it.. I can't link directly to the page.
http://www.installuniversity.com
Originally Posted by GM
SAE 75w-90 Synthetic Axle Lubricant (GM PN 12378261) or Equivalent. W/ a complete drain and refill, add 4oz (118ml) of Limited SLip Axle Lubricant
Old Jan 23, 2007 | 06:21 PM
2000GTP's Avatar
Injuneer has an awesome writeup for when he did his 12bolt install: http://members.aol.com/InjuneerZZ/Strange12.htm
Old Jan 24, 2007 | 12:06 PM
Thanks for the links guys! And yeah, it would be a TA Girdle install.
Old Jun 5, 2008 | 01:54 PM
cals400ex's Avatar
on it write up it says to release the emergency brake. how is that accomplished?
Old Jun 5, 2008 | 01:55 PM
FirstYrLS1Z's Avatar
at the spring end of the e-brake cable at the backing plate/dust sheild.
Old Jun 5, 2008 | 01:59 PM
cals400ex's Avatar
does the dust shield need to come off? i just dont' see how to unhook it unless i pull it off of that lever with some force.
Old Jun 5, 2008 | 04:07 PM
Lower the e-brake handle, to release the e-brake's grip on the rotor.
Note that the procedure is for the LT1 rear, with a different e-brake setup than the LS1 cars.
We don't know what car you have, since you didn't include a signature.
Old Jun 5, 2008 | 04:33 PM
cals400ex's Avatar
sorry, it is a LS1. i think i figured it out though.
however, i couldn't figure out how to disengage the parking brake lever. i remember you stick a screwdriver in there but i couldn't remember what you had to push? this is for removing the consol now (sorry, two topics in one thread).
Old Sep 22, 2008 | 08:46 PM
capncrunch's Avatar
Rear ends
Hey Injuneer!
I was looking on the third-gen site, & someone was asking what the different rear-end widths were for the third gen Camaro, then the fourth gen (he said that the LT1 & the LS1s were different widths from one another, & from the third gen cars)?
Is there a difference between all three of these? Got a URL for the guy to read it? Could you let me know, please!
Thanks! And sorry to 'Jack' your thread, Eagleknight!
John
Old Sep 22, 2008 | 10:58 PM
If there is a difference between the LS1 and the LT1 4th Gen rear axle assemblies, it is minor. The 3rd Gen rear is somewhere between 3" and 4" narrower than the 4th Gen rear, depending who you believe. Strange shows in their engineering drawings for the bolt-in replacement 12-bolts that the difference is 3".
Here's a post from the "Wheels and Tires" forum by a guy who put a 4th Gen rear in a 3rd Gen. He measured the difference as "about 2" per side", and indicates he heard the LS1 rears were 1/8" shorter per side than the LT1 rears:
https://www.camaroz28.com/forums/sho...d.php?t=622922
All the mounting points are identical. Just the length of the tubes is different.
Old Sep 28, 2008 | 09:41 PM
capncrunch's Avatar
Thanks!
Thanks for the info!
John
dawg irocz
3rd Gen / L98 Engine Tech
Feb 10, 2015 10:33 AM
Chet1185
Feb 4, 2015 09:51 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
