Broken Tranny Mount
Old Jan 19, 2007 | 08:50 AM
94camarozz28's Avatar
Broken Tranny Mount
I have 94 Z28, I posted I thread about a month ago about my tranny shifting hard at off the line. Since then I have found the problem it' s the tranny mount. Now that I know what the problems is I can correct it. Should I use the stock tranny mount or the energy suspension tranny mount?
Old Jan 19, 2007 | 09:27 AM
95LT1conv's Avatar
ge the poly mount
Old Jan 19, 2007 | 11:46 AM
romoranger's Avatar
get the poly. my car snacked on about 4 rubbber mounts before i got smart.
Old Jan 19, 2007 | 11:58 AM
That's what everyone has told me to get. I just wanted to get a few more opinions. How much stronger are the poly mounts?
Old Jan 19, 2007 | 12:10 PM
95LT1conv's Avatar
put it this way, if you break a poly mount, you have other seriuos issues you need to address
Old Jan 19, 2007 | 12:28 PM
Critter's Avatar
poly mount is $36ish easy to install. and you'll never buy another. go get one.
Old Jan 19, 2007 | 12:34 PM
95LT1conv's Avatar
http://www.jegs.com/webapp/wcs/store...43960_-1_10729
$21.99
Old Jan 19, 2007 | 12:59 PM
JAG05's Avatar
I have broken eight stock tanny mounts but it has a lifetime warranty so no cost to me. But I put a set of ET on teh other day and one the 3rd launch broke one, will the poly hold up to this? The only reason I havent got one yet is cause one of my friends has a TA and he said he broke the poly one fast the the rubber one.
Old Jan 19, 2007 | 01:17 PM
2000GTP's Avatar
The poly will be stronger versus the stock rubber mount. However, the only drawback will be the likelihood of extra vibrations.
Old Jan 19, 2007 | 01:35 PM
romoranger's Avatar
i have not even scathed my poly mount. my car isn't really that big of a deal (41x whp, run slicks), but it works awesome
Old Jan 19, 2007 | 07:44 PM
n4b's Avatar
n4b
I used the solid poly mount and it solved all my problems, I can't see you breaking one of these mounts, I am over 600hp and 3800lbs with no problems.
Old Jan 19, 2007 | 09:21 PM
Thanks for the help everyone.
Old Jan 19, 2007 | 09:28 PM
94 NO TOP Z's Avatar
You can usually pick up at your local auto store... Autozone, Pep Boys, etc. The mount hasn't changed in 50 years and is pretty common.
Old Jan 19, 2007 | 09:50 PM
I found one on LMPerformence parts.com for $25 plus $10 shipping Advance auto parts has one for $65. I think I'm going to order it from LM.
Old Jan 20, 2007 | 12:20 AM
94Zman's Avatar
Tried it, with a A4 found it transfered too much drivetrain noise... leaving me to break stock ones, about 4 so far
dylan1303
Aug 12, 2015 02:00 AM
dylan1303
May 22, 2015 12:24 PM
mattszm6
Dec 14, 2014 07:09 AM
ZBLKHELLRZR
Aug 18, 2002 07:57 AM
rpm4lalo
Aug 3, 2002 02:35 PM
