ac/heater
Old Jan 17, 2007 | 01:40 PM
bigdawg6114's Avatar
ac/heater
I have a 1994 camaro z28, my ac or heater will not work properly.
Air will blow from the vents, but my heater will not get hot when its cold and my ac will not get cold when its hot outside. Do anyone have any ideal what my problem could be...?
Old Jan 17, 2007 | 02:06 PM
Spllouder's Avatar
sounds like two promblems, i would start with the heat first since its winter and worry about the a/c in the summer .
first make sure your coolant is full , fell your heater hoses is one hot and one cold ? if so your heater core could be blocked up . check this first , also make sure your thermostat is working propely , what temps are you getting ? we need more input .
Old Jan 17, 2007 | 04:08 PM
The coolant is full and i have a 160 hypertech powerstat, temp is usually around 180
Old Jan 17, 2007 | 04:10 PM
I also notice that my my ac/heater switch settings doesn't seem to be changing when i move it to defrost, it only blows out of the top vents even when i switch to bottum only as well
Old Jan 17, 2007 | 04:24 PM
BUBBA's Avatar
Better get a diagram of your system showing the various valves, switches, etc. Then check to see if they are working properly. I realize I am over simplifying, but I haven't had the problem with my F-Body, but have had things like that happen with other cars and trucks.
Go to dealer and have them pull up the diagrams and make copies for you and go from there.
Doesn't sound like problem with cooling system per se, JMHO
Old Jan 17, 2007 | 10:48 PM
Shoebox has info on the HVAC vacuum system on his website. The check valve in the vacuum line from the engine is a common problem. He has a diagram of the system, and photos of the check valve.
http://shbox.com/1/4th_gen_tech1.html
I'll move this to "General F-Body Tech....." since it isn't engine-specific.
Old Jan 19, 2007 | 09:05 AM
Thanks! this site is great
MeenZ28
Nov 3, 2011 12:34 AM
steely_chris
Jun 15, 2011 03:35 PM
Big White Machine
Oct 21, 2007 04:11 PM
Joe Brodman
Apr 17, 2003 08:12 AM
joink
Mar 15, 2003 07:02 PM
