Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Hard start & stinks like fuel?
Old Jan 7, 2007 | 07:42 AM
White94Z6's Avatar
When I start my car I have to turn the key on and off twice before the car will start.Then once its running it stinks like gas really bad while running, any idea on what this problem is?
Old Jan 7, 2007 | 08:27 AM
Hard starting often is the result of the fuel system losing its prime pressure too fast. That can be caused by things like a faulty check valve in the fuel pump, a broken diaphragm in the fuel pressure regulator, leaking injectors, or leaking fuel lines.
You definitely need to check for leaks in the fuel lines and the FPR. Can you pin the smell down to either the engine area or the fuel tank area? Have you checked the fuel pressure?
Old Jan 7, 2007 | 08:56 AM
White94Z6's Avatar
The fuel pressure jumps to 48 then bleeds down, faster then normal I think?
Old Jan 7, 2007 | 11:56 AM
mrmint69's Avatar
I get the fuel pressure to maintain for about 30 minutes then it bleeds down slowly. How long does it take for you?
Old Jan 10, 2007 | 02:50 PM
White94Z6's Avatar
It will bleed down in about 2-3 minutes, then once you get it started it seems to run fine other then the real strong gas smell from the exhaust and the bad gas milage.
Old Jan 22, 2007 | 08:55 AM
mzgp5x's Avatar
I had that same problem. Bad fuel regulator (Aeromotive). Gas would leak thru to the intake manifold thru the rubber diaphram. Discovered by smell of gas on the Vac line to the regulator. My fuel pressure gage did not indicate this problem due my tap being not @ the fuel rail.
HectorM52
Jul 30, 2017 11:46 AM
Alex Barnes
Jan 24, 2015 10:21 PM
Jessie4tin
Jan 7, 2015 08:53 AM
