ATF at the back the trans
Old Jan 2, 2007 | 10:30 PM
neil350's Avatar
Right at the back tail shaft I noticed ATF, looks like its speeing, I dont see puddles under the car, wondering if thats normal?
Old Jan 3, 2007 | 10:37 AM
2000GTP's Avatar
Sounds like you will need to replace the tranny tailshaft seal, its a pretty common place to leak, but not difficult to repair.
Old Jan 3, 2007 | 02:53 PM
neil350's Avatar
I'm guessing this would be the perfect time to swap drive shafts as well?
Old Jan 3, 2007 | 03:05 PM
95LT1conv's Avatar
if you have one to swap, then yea perfect time
Old Jan 3, 2007 | 03:16 PM
2000GTP's Avatar
Yep, your gonna have to pop it off anyhow. The aluminum LS1 driveshaft is a popular upgrade but the other question comes up, will it be enough for your current or future power goals?
Old Jan 3, 2007 | 04:39 PM
neil350's Avatar
Probably, any case may as well fix this leak before it gets bad and change the ATF fluid and filter.
PCLZ28
Dec 24, 2015 05:19 PM
jb4xx
Feb 2, 2015 10:00 PM
Jan 13, 2015 09:52 PM
rockync7
Jan 1, 2015 05:10 AM
Jul 4, 2005 05:00 PM
