Eliminating ABS computer and remote door lock "computer"
Old Dec 17, 2006 | 05:00 PM
Mikes 1994 z28's Avatar
Can these two boxes be removed from my car without interfering with the car? Im not worried about codes that are thrown - b/c I will just have them deleted when I get my PCM retuned. But im wondering if I just unplug the two boxes if my car will cease to run/fun properly
Old Dec 17, 2006 | 05:28 PM
Please post only "engine" topics in LT1/LT4 Engine Tech.
Moving.......
Old Dec 17, 2006 | 07:39 PM
RE AND CHERYL's Avatar
If your car is the 1996 in your sig, the ABS computer can be removed but the keyless entry is in the BCM which cannot be removed unless you wish to rebuild much of the electrical system. Much of the electrical system is tied into the BCM.
If it's the 94 in your user name. Yes you can remove both.
Re'
Old Dec 18, 2006 | 07:08 AM
Re'
It's a '94 engine being swapped into a 96 body. The complete dash harness was/is being swapped over. Where is the BCM located?
Old Dec 19, 2006 | 05:51 PM
94arcticwhiteM6's Avatar
under the dash on passenger side i believe.
Victor Lamb
Aug 26, 2017 02:52 PM
Heathen1
Jan 2, 2016 04:27 PM
warmeck
Mar 24, 2015 10:52 PM
Rod Bender
Jan 3, 2015 03:15 PM
Jeff1904
Jan 3, 2015 12:00 AM
