B&M Shifter install help
I am about to do a swap for my stock hurst for a B&M Ripper Shifter. But the person I am buying it from said that we might not be able to install the shifter because we need to adjust the stops for a new shifter and adjust the first and researve. He doesn't know how to do it neither do I. If these adjustments are true can someone please guide me to some instructions on how to install the B&M Shifter. I need help fast guys, we're doing the swap tomorrow morning. Thanks everyone!
The "stops" are simply threaded bolts on the gate. When you see the shifter plate, there will be bolts to restrict the movement from the neutral postion to the "in gear" positions. I currently have mine backed almost all the way out on my Pro 5.0 shifter...
Just installed the B&M shifter and to tell you the truth I don't feel that its any of a shorter shift then the hurst shifter that comes in WS6 and SS. The guy I swapped with didn't have the stop screws so we installed it without adjusting the stops. Is that maybe why I am not noticing a shorter shift then the hurst? Need help again guys, thanks!
The stops aren't going to make a big difference and if you screw them in too far, you run the risk of not fully engaging, or popping out of gear. How long is the threaded part of the stick? Maybe you could cut it down, or get a shorter stick?
Well the stick on the B&M is one peice so I can't replace the stick for a shorter one. I purchased a short stick from ebay and used that for my stock hurst shifter which was great. The B&M is just a little longer then the short stick that I have. The only solution is to find someone to trade my B&M for a Pro 5.0.
