2 things, maybe frank will chime in
Old Dec 14, 2006 | 08:44 PM
Daniel6718's Avatar
other day a guy comes in with he ls1 cam plus n20 car, semi gutted i guess, has no 3-4 gears...so we send it back to the builder and the stall to have it checked and redone. lucking it had a 1 yr warranty and they fixed it but said they wouldent do it again. evidently the 24000 gvw cooler isnt big enough for a 4000 stall, and doing burnouts ruined it. i guess that means my cpt tranny wont last doing all these burnouts at the track(sarcastic)
i also wanted to say it wasnt the brightest but last night i ran our shops tt 350z, made 440 hp 2 times, from 40-115 i put about 3 cars on him, then i guess my bottle psi dropped some from 40 again to about 150-160 we were next and neck, i started pulling in 4th from 130-155ish
weird thing to look down and know your in 4th about to touch 6500-6700
good thing is i know that my tranny will be perfectly fine! thanks frank!!!
Old Dec 14, 2006 | 10:30 PM
12SCNDZ's Avatar
Daniel,
Sounds like your friend is getting fed a bunch of BS. Is he running his cooler "in series"? Is it also still running through the factory cooler? If so, a 24,000 GVW cooler should be fine, as long as it's flowing good. Is it a "stacked plate" or "tube and fin" cooler? The T&F coolers aren't very efficient. The SP coolers are much better. B&M coolers are SP design.
You've got our number, if your buddys trans goes again. We don't build excuses...We just build the best transmissions on the planet.
Thanks,
Frank
CPT
Old Dec 15, 2006 | 12:16 AM
Daniel6718's Avatar
yes i know he was, felt bad for the guy, supposively it was a 1500 build, it is in series and i have no idea the differance in the coolers, its just like mine, looks similar to a condensor...i informed them before we repaired it of you, when he comes back ill offer again...
Heathen1
Jan 2, 2016 04:27 PM
silvermansteve
Mar 4, 2015 05:02 PM
Hal Fisher
Sep 14, 2002 09:36 PM
Fbodfather
25
Jun 21, 2002 04:12 PM
