Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
fuel line/block trouble ....HELP..please
Old Dec 10, 2006 | 11:07 PM
Friday13th's Avatar
I was changing some gaskets over the weekend and when I was able to get everything back together except one thing. The fuel rail on my 3.4 and the injectors are in place but I can not get the fuel lines back into the fuel block. There are two O-rings inside the fuel block and I keep trying to push the lines in but they won't go in. I took the rings out and the lines aren't in the fuel block tight enough.
Does anyone have an idea on how to get these lines in?
Any help would be appreciated.
Shaun
Old Nov 18, 2008 | 09:10 PM
94rebuild's Avatar
Make sure you are lined up as straight as possible with the f.block and you have to have all the o-rings on it or in it. Try a light coat of some type of lubricant, grease or something pretty thick wont take much on your o-rings. Hope that helps
DirtyDaveW
Dec 1, 2016 05:37 PM
4586
Apr 24, 2015 01:03 PM
Cam's maro
Mar 24, 2015 08:09 PM
armedtrigger
Feb 24, 2015 08:30 PM
warmeck
Feb 2, 2015 12:44 AM
