camaro rear-ends-how different-6cyl-8cyl-?
Old Dec 10, 2006 | 06:10 PM
ledfut1's Avatar
Cool camaro rear-ends-how different-6cyl-8cyl-?
I have 95 Z-28, 350 auto.. Car available for parts had 6 cyl. with manual trans. Will the rear-end work in my car. Both cars are 95`s. They look alike except for motor and tranny..thanks
Old Dec 10, 2006 | 06:19 PM
jay_lt4's Avatar
it will work but the early v6 cars have drum brakes, your z28 has disc
and gear ratio may be different
Old Dec 10, 2006 | 06:39 PM
ledfut1's Avatar
Can the punkins come out of the rear-end.I mean, dont know much about newer cars but I use to carry an extra rear-end around in my `63 Chevy Impala. Had a four spd and tearing out rear-ends was common..Just pop out the bolts, pull the punkin out and put in a new, or used, one., replace driveshaft and go.
Old Dec 10, 2006 | 06:58 PM
The Engineer's Avatar
GM rear-ends (10 and 12 bolt from the late 1960s to present) "do not" have pumpkins that come out as one assembly. It is the Ford 9” rear-ends that have a removable pumpkin.
WD
Old Dec 11, 2006 | 01:41 PM
V6's did not come with a posi rear as standard, only as an option. Disc brakes were also optional with the V6's.
My "purchased new" 1963 Impala 300/327 3-speed left the factory with a 3.36:1 removable rear axle "pumpkin".... quickly replaced with a close ratio T10 and a 4.11 pumpkin. When the 4.11 rear disintegrated, the stock 3.36 was a simple replacement. Those were the "good old days"
Mine....
63 Impala restoration photos (not mine):
Old Dec 12, 2006 | 07:29 PM
ledfut1's Avatar
Well Mr. Injuneer.. I sure do thank you for that..I was feeling pretty stupid there for a while..those were the good ol days..and thanks for those pics..I owned my `63 back in the early 70`s..
Old Mar 11, 2010 | 05:30 PM
projektz_born's Avatar
if the posi/limited slip and the disks were options does that mean, if it has those 2 options, that it is the Y87 package? i found a 4th gen rear out of a V6 96 camaro that has disks and limited slip.
Old Mar 12, 2010 | 09:24 AM
Both posi and disc brakes were included in the Y87 package (along with a quicker steering ratio). The Camaro White Book does not list those options as being available seperately in 1996.
What are you going to put the 96 rear axle in?
Old Mar 12, 2010 | 09:44 AM
83 camaro with rear drums and non LSD
F'n1996Z28SS
Aug 23, 2023 11:19 PM
CARiD
Jan 14, 2015 04:00 AM
ChrisFrez
Dec 21, 2014 09:47 PM
ChrisFrez
Dec 15, 2014 03:09 PM
