Security system
Old Dec 5, 2006 | 04:26 PM
Red96Lt1's Avatar
Security system
So I went out to my car today and I turned the key and it wouldn't crank. It just had the security light on. I haven't done anything recently to my car that would warrant this. Is it possible that the little resistor thing on the key has worn out? It cranked about 5 min later.
Old Dec 5, 2006 | 04:51 PM
Critter's Avatar
not likely but possible...use a spare for a while and find out.
Old Dec 6, 2006 | 07:26 AM
Red96Lt1's Avatar
Apparantly I was right. The resistor on the side of the key was pretty worn out. Especially when compared to a new key. The guy at the dealership said that this is a fairly common problem in older cars.
Old Dec 6, 2006 | 03:06 PM
jhthornley's Avatar
me too
Funny... I had the same exact problem this morning.
I got the list of pellet codes from Rob's site, and am off to buy a resistor(s)..
Looking forward to getting under the dash again..
Anyway, that's the deal... Had to use my wife's copy of the key to get it started.
Will paypal Rob some $green$, as his site is awesome..
later
JT
Old Dec 6, 2006 | 03:10 PM
Red96Lt1's Avatar
So are you just going to by pass it then?
Old Dec 6, 2006 | 07:18 PM
jhthornley's Avatar
yeah... I just went to Radio Shack and checked the resistance of my key pellet (1870). I then snagged 3 resistors (1.5K, 270 and 100 ohms) and have soldered them together...
Tomorrow (when its light) I'll pull the lower dash and find the VATS connection and hook into those wires there...
touch wood it'll be easy enuf???
I'll post a follow up.
JT
Old Dec 8, 2006 | 10:47 AM
BradcTA's Avatar
JT
Or you could just buy a new key for $34 and be done with it. A new car is a lot more expensive than a new key...
Old Dec 8, 2006 | 05:21 PM
jhthornley's Avatar
turned out to be
the connection btn the 2 white wires and the purple one (and ???) going to/from the VATS module was loose...
Before I started mugging the white wires w/ the resistor route I just made the connection "good", and was in business...
JT
jwade88
Jun 14, 2015 09:38 PM
blac94Z
Jun 11, 2015 06:17 PM
moparman
Mar 5, 2015 08:47 AM
fpete1992
Dec 11, 2014 03:51 PM
