advice on fouled plugs
Old Dec 4, 2006 | 12:45 AM
Critter's Avatar
Angry advice on fouled plugs
Its 9 degrees outside and has been snowing so the car was parked for a week. i tried to start it and was trying to turn over but wouldn t. so like a moron i held it to the floor and kept trying. now i assume the plugs are fouled or close to it. any advice. thanks critter
Old Dec 4, 2006 | 06:04 AM
Dave89IROC's Avatar
holding the throttle to the floor cuts off all fuel, so shouldn't have fouled the plugs by itself
and you said it was trying to turn over?
you mean it was cranking but wouldn't start or that it was cranking slow?
Old Dec 4, 2006 | 09:35 AM
Critter's Avatar
Cranking and tried to start. but never fully did.
Old Dec 4, 2006 | 12:20 PM
Critter's Avatar
think i might have found somthing out that may be causeing this. my ground to the pcm was cut, so i'm going to try to fix that and put some heet in the tank.
anything else i am missing?
Old Dec 4, 2006 | 06:17 PM
If the coolant temp sensor wasn't accurate, and not telling the PCM how cold the engine is, it could cause it to have a hard time starting.
Old Dec 4, 2006 | 07:14 PM
Critter's Avatar
so are you talking about the sensor on the driverside head, or just grounding out the wire i am speaking of
Old Dec 4, 2006 | 08:05 PM
95LT1conv's Avatar
the sensor on the front of the water pump
Old Dec 5, 2006 | 02:40 PM
Critter's Avatar
plugs are black and have a 33 gap. im gonna bump it 2 45
Firechicken350
Jun 6, 2015 11:25 PM
z28cam1993
May 29, 2015 10:17 PM
dplatt3
V6 Tech
Apr 30, 2015 10:44 AM
captcorvette
Mar 7, 2015 12:37 PM
David Dorris
Jan 17, 2015 08:10 PM
