V6 heater problem
Old Nov 30, 2006 | 02:48 PM
myzisgon's Avatar
V6 heater problem
I just signed up here and would like to ask a question. A friend has a 94 Camaro 3.4 V6 and the heater just doesn't get as hot as it should. It has a new 195 degree thermostat but the temp gauge only comes up to the first mark and on these cold morning it will barely get warm. I traced both hoses from the engine to firewall and didn't see any heater control valve outside. Is there one inside or do ya'll have any other suggestions?
Old Nov 30, 2006 | 02:54 PM
2000GTP's Avatar
It is pretty common for the heater cores to get clogged up and they don't perform as well as they should. Take the heater core out and try flushing it out with a hose.
Old Nov 30, 2006 | 07:40 PM
AlfredB18's Avatar
I'm betting that heater core has never been touched or cleaned out....it's 12 years old...toss it.
All that thing is is a mini radiator....12 years of crap won't come out easily.
Old Nov 30, 2006 | 09:08 PM
FunkZ's Avatar
The temp sensor is in the front of the driver's side head. If the engine coolant isn't getting above 160° it isn't a problem in the heater core. Sounds like the thermostat is stuck open, although I know you said it was just replaced.
Old Dec 4, 2006 | 12:44 PM
PentaVolvo's Avatar
My brothers camaro wasnt gettin heat for basically an entire winter but they only drove short trips so didnt notice till i was in it one day and it had been 25 min and i barely had luke warm air, a 5 dollar theromostat later and good as new
kksi
Feb 17, 2015 10:41 PM
MattFick
Feb 15, 2015 10:16 PM
Jan 23, 2015 01:13 PM
Britbilly
Jan 7, 2015 08:49 PM
pologreen97z
Dec 2, 2014 10:42 AM
