Help! Troubleshoot Power Windows
Old Nov 29, 2006 | 06:41 PM
SSquared's Avatar
My '98 SS is on it's third drivers door power window motor. It's been working fine and today, it decided not to go up....not even budge. How can I trouble shoot the rocker switch or which wires would I touch to bypass the switch. There seems to be four wires associated with each window switch. The Passenger door window works fine from both of it's switches.
I read about bypassing the relay mod and removing the thermal bypass but not ready to tackle that.....yet.
I just want to see if the motor is working or not.
Old Nov 29, 2006 | 06:50 PM
T56LS102's Avatar
Well an easy way to do it would be to send direct power to the widow motor
to see if it moves that way, if it does then you would probaly want to go after the relay or switch
Old Nov 29, 2006 | 07:17 PM
SSquared's Avatar
Thanks for the quick reply, I have the switch panel removed from the door panel so I can see the wires. Which wires would I touch?
Old Nov 29, 2006 | 10:29 PM
T56LS102's Avatar
There should be two wires coming from the motor send power to them from a 12 volt power source to go one way and then switch the wires around for the motor to go the other way.
See if that works
Old Dec 8, 2006 | 04:03 PM
SSquared's Avatar
Talking
Thanks, I tested the power wire with the up / down wires while toggling the switch and my test light lit. I could also hear the relay click when toggling the switch, but the window didn't budge. This is the first time I have experienced the motor just dying with no forwarning.
I replaced the motor and the window works great.....thank AutoZone for Lifetime warranties.
Keenan
Jan 19, 2023 12:24 PM
Heathen1
Jan 2, 2016 04:27 PM
capebuf
Jan 13, 2015 07:22 PM
XtremeLt1
Sep 13, 2002 08:50 PM
MilkyClr69
Jul 29, 2002 10:01 AM
