High boost single coil users. Questions
Old Nov 29, 2006 | 03:43 AM
ZBLKHELLRZR's Avatar
Question High boost single coil users. Questions
This goes out to all the guys running 18+psi. What is your ignition system consisted of? How are you managing to keep the spark from blowing out? As much as I hate it but I'm seriously thinking of going back to a single coil unit like a crane setup. I currently have the Delteq which I love for the record but I'm not to sure about controlling timing with at all w/ the FAST. 383 w/ F1-22-24psi. Really won't know until a couple of days when I fire it up finally for the 1st time. I also am not fond of the typical single coil setup putting all that stress on the opti but in the past I've had no issues w/ my Accel 300+ setup w/ the factory opti for 10 yrs straight. It seems more or like a hit or miss issue.
My ultimate would be the delteq w/ the Gen III dynaspark but again no timing control.... nd as far as the DIS-4 is concerned I'm not too familiar with it.
So again what setups do you have and how have they performed over time.
Thanks!
Old Nov 29, 2006 | 06:21 AM
xxsaint69x's Avatar
stock coil, stock opti, stock pcm...18psi eheh
Old Nov 29, 2006 | 06:44 AM
Marcin you aren't running a ignition box? That's pretty amazing if so.
Old Nov 29, 2006 | 01:54 PM
Jeff 96 SS's Avatar
MSD digital 6 box, msd coil, stock opti, 22#s, stock computer, spinning to 7k. No problems with the spark blowing out I also use NGK race plugs gapped .32
Old Nov 29, 2006 | 02:47 PM
CALL911's Avatar
Stock opti, MSD coil, MSD digital 6 box, 15.3#'s of boost at 7,000 RPM. I had issues on the dyno though of it blowing out the spark every once in a while at 6300 or so. After taking the tuners advice, we re-gapped the plugs a little tighter (if interested I'll try to get the exact gap specs). After that she would pull up to 7,000 RPM all day with no problem.
BTW, hows the car coming? You got that thing on a dyno yet?
Old Nov 29, 2006 | 03:22 PM
rskrause's Avatar
Moderator
Opti, Accel coil, MSD6, plug gap at 0.35, good wires (changed every year). No spark issues.
Rich
Old Nov 29, 2006 | 08:44 PM
blown383's Avatar
What plugs are you guys running and at what gap?
-B
Old Nov 30, 2006 | 01:30 AM
Call911 I haven't fired it yet. I was waiting on a clamp that never showed up but I'll fire it w/ out it this wk FINALLY. I was playing around w/ the base tune this wkend and made a copy of the original just in case the original does better than what I did.
B I'm running TR6's gapped at 0.30 as I didn't want to chance it w/ 0.35 even though that's what was recommended to me.
Old Nov 30, 2006 | 03:12 AM
blown383's Avatar
Why the tighter gap?
-B
Old Nov 30, 2006 | 04:54 AM
rskrause's Avatar
Moderator
Very cold NGK's. Narrower gap requires less voltage to jump, however too small a spark can cost hp. It's a trade off.
Rich
Old Nov 30, 2006 | 02:42 PM
engineermike's Avatar
Stock opti with MSD cap and rotor. Crane HI6TR and MSD coil. Plug gap at .025". 24 psi and no problems - with the ignition at least.
The turbo GN guys did a test a while back and found that every time they reduced plug gap, the power increased. They did see diminishing returns, though, so they stopped at somewhere around .018".
Mike
DirtyDaveW
Dec 1, 2016 05:37 PM
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
Jan 23, 2015 01:13 PM
Queens94z28
Dec 20, 2014 09:11 PM
