patriot 226 cam?
Old Nov 28, 2006 | 08:43 AM
stephen griner's Avatar
patriot 226 cam?
Anyone using this cam? what kind of numbers did it put down? Mods? A4 or M6? Is it worth buying, installing, and tuning for this cam or should I spring for a different cam?
Thanks,
Stephen
Old Nov 28, 2006 | 09:00 AM
SSpdDmon's Avatar
I would expect ~380rwhp w/out heads & ~410rwhp w/ heads (depending on your setup). Should be pretty driveable. Like any cam swap, having the right supporting mods is key.
Old Nov 28, 2006 | 12:39 PM
2002ss's Avatar
what kind of supporting mods are you talking about?
Old Nov 28, 2006 | 12:52 PM
teke184's Avatar
lid, intake manifold, headers, good exhaust
all will play an important roll in how the cam performs
things like torque converter will affect how the car drives
Old Nov 28, 2006 | 01:11 PM
SSpdDmon's Avatar
Yup, those are the basics. Help the motor spin/breathe easier and you'll see more power. An underdrive pully and electric water pump can be the difference between a 385rwhp car and a 400rwhp car (if you going to play the numbers game).
Old Nov 28, 2006 | 01:23 PM
teke184's Avatar
yeah i just wish the WPs were less than $550
i would so have one!!!!
Old Nov 28, 2006 | 05:28 PM
Zitty'sZ's Avatar
Thanks,
Stephen
I bought this cam and I will try to get it put in over the holidays so I don't have any first hand experience yet, but I met a guy at a local car show who was running this cam and it sounded bad ***. He told me that it has very good street manners and pulled really good, this helped me in deciding to buy this cam! He said it ran Ok with the stock tune, but he had the car tunned and said that it was alot better afterwards.
Old Nov 28, 2006 | 07:32 PM
Greed4Speed's Avatar
I have a 226 grind (GTP420) with more lift and a 112 LSA in my daily driver. It is basicly everything you heard about the 224, just slightly larger. My car is a 00 SS M6, lid, LS6 intake, MAC headers, carsound cats, and catback. Other mods are suspension related.
It ran ok with the stock tune, except at idle. It has some decent power. Enough for me to get squirrelly from a roll once i got around 4800 RPM up in the first 2 gears. Had to lift twice while I was racing a modded Z06.
Supporting mods should include springs and pushrods too. You'll end up looking into an aftermarket clutch eventually too.
I haven't dynoed it yet, but another local guy was running a 226 grind and made a hair over 380 whp w/lid, intake, LTs, ORY, catback, tune, etc.
Not a bad grind, but it all depends on what YOU want out of a cam.
Old Nov 28, 2006 | 08:08 PM
SSpdDmon's Avatar
Originally Posted by Greed4Speed
...I haven't dynoed it yet, but another local guy was running a 226 grind and made a hair over 380 whp w/lid, intake, LTs, ORY, catback, tune, etc....
Hmmmm...that sounds familiar.
Old Nov 29, 2006 | 07:48 AM
Thanks for all the replies, I have an LS6 intake, SLP lid, exhaust, and I will be putting longtubes on as well as 918 springs, pushrods, and a dyno tune. I would like to get a pulley and electric water pump but that may be a bit later on.
Heads would also be nice but they are very expensive, for good ones anyway.
They would be in the very distant future.
Thanks,
Stephen
Old Nov 29, 2006 | 09:37 AM
teke184's Avatar
"I would like to get a pulley and electric water pump but that may be a bit later on."
that $700-800 would be better used if you put it towards a set of budget heads.
there are a few places that do ported heads for about $1000...and will gain you MUCH more than a pulley and Wp combined.
Old Nov 29, 2006 | 09:50 AM
AL SS590 M6's Avatar
Moderator
Yeah the best reason to get an electric waterpump is if you bracket race a lot. I love mine for that. It pumps way more water at low rpm than a pulley driven pump and I can make a run with the car and it will be back to 17x° by the time that I get back to the pits. But $500 for a small hp gain alone?
rideordie
Nov 5, 2019 04:52 PM
alex5366
Feb 17, 2015 08:12 PM
Queens94z28
Dec 20, 2014 09:11 PM
Queens94z28
Nov 20, 2014 06:03 PM
