exhuast question
Old Oct 24, 2006 | 07:21 PM
BMWKillR's Avatar
exhuast question
Hey guys. My borla quad tip system flows the exhaust out of only the driver's side. There is only a slight bit (hardly noticeable) coming from the passenger side. Any reasoning why that is? The current setup may bypass the muffler somehow. Its just a little annoying to have my car running so rich and have only 2 tips covered in soot...I want all 4 to be black inside!! Also, I beleive I have the closed plate on.
-Adam
Old Oct 24, 2006 | 07:35 PM
Red95M6Z28's Avatar
You answered your own question. The closed plate send all the exhaust through the muffler. So all the exhaust gases go out the driver side. Take the plate out and it will go though both sides.
Old Oct 24, 2006 | 08:09 PM
BMWKillR's Avatar
I don't have the "open plate" can I order another from somewhere? I want the car to be a little louder as well as flow differently.
Old Oct 25, 2006 | 07:02 AM
Red95M6Z28's Avatar
I could be wrong, but cant you just put the 2 exhaust sections together with no plate?
Old Oct 25, 2006 | 08:19 AM
teke184's Avatar
take the plate to a machine shop or a welding shop....they should have some 1/8" steel plate that they can cut to fit your needs. make a few and just drill different size holes out of the center.
the "wide open" plate would probably shift your currrent problem...99% of the exhaust will go out the other side.
grgguy
17
Feb 23, 2015 07:57 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
jeff94z28
Sep 11, 2002 02:01 PM
dansam
Jul 20, 2002 01:10 PM
