Defective SLP Skip-Shift Adapter?
Old Oct 23, 2006 | 07:42 AM
RKHiPerformance's Avatar
This weekend I added an SLP Skip-Shift adapter to my Dad's bone stock 2002 SS.
Once installed, it became very hard to engage reverse. It was possible to find reverse, but it took a bunch of effort. Once I removed the adapter, reverse was just as easy to access as it had been originally.
I removed and reinstalled the adapter several times, and each time was sure to confirm proper orientation of the plug and proper engagement of the pins. Can something be wrong with the SLP adapter? There's not much to it...
I'll be calling SLP today, but I was wondering if anyone here has experienced this or has any suggestions.
Thanks,
Rick
Old Oct 23, 2006 | 09:32 AM
OBE1 95Z28's Avatar
Re: Defective SLP Skip-Shift Adapter?
The Skip Shift eliminator is just a resistor to fool the PCM into thinking that the connector is plugged in when it is really bypassed. Verify that you're plugging it in to the correct location (although I thought the connectors were different styles to prevent them from being plugged into the wrong spot).
Old Oct 23, 2006 | 10:21 AM
You plugged it into the reverse lockout solenoid connector rather than the skip shift solenoid.
Old Oct 23, 2006 | 11:17 AM
Yup...That's what I did...wrong connector.
(embarrassed)
Thanks for the help!
Old Oct 23, 2006 | 12:17 PM
I pulled the connector off (what I thought was) my skip shift solenoid about 2 weeks after I bought the car new in 1994. I managed to unplug the vehicle speed sensor (VSS) and it took about 30 seconds to realize after I started driving the car and the SES light cam on and the speedo didn't work. We all make mistakes..... that's how we learn.
G-BODYT56
Jan 14, 2022 11:14 PM
GREEN3112
Feb 10, 2019 09:19 PM
n2oblkz
Oct 22, 2015 02:31 PM
n2oblkz
Oct 12, 2015 01:53 AM
form94
Sep 23, 2015 07:30 AM
