who the hell makes lt1 cranks larger then 3.75?
Old Oct 22, 2006 | 06:41 PM
BadBowLT1's Avatar
who makes larger stroke cranks and where can i get thme i know callies makes a 3.875 any help?
Old Oct 22, 2006 | 07:32 PM
rskrause's Avatar
Moderator
Re: who the hell makes lt1 cranks larger then 3.75?
Any SBC crank for a 2-piece real seal will work. Callies, Lunati, Eagle (Chinese forging), etc. make 1-piece rear seal 3.875" cranks. there must be others as well. You can use a crank with a 2-piece rear seal with an adapter.
10051118 Crankshaft Seal Adapter
A leak-resistant one-piece rear main bearing seal was introduced on production small-block V8 and V6/90º Chevrolet engines in 1986. Crankshafts in these engines were also redesigned to accommodate the new one-piece seal design. This adapter kit allows you to install an early-style crankshaft designed for a two-piece seal in a block which is machined for a one-piece rear seal. This seal adapter can also be used when installing a heavy-duty crankshaft in a cast iron Bow Tie small-block or Bow Tie V6/90º block machined for a one-piece seal.
Rich
Old Oct 22, 2006 | 07:43 PM
OneFlyn95z28's Avatar
I have seen 4 and 4.125 with the aqdapter
Old Oct 22, 2006 | 07:48 PM
captaindbol's Avatar
Eagle 3.875 and 4" 1pc seal
cncmotorsports.com
F'n1996Z28SS
Aug 23, 2023 11:19 PM
HectorM52
Jun 23, 2016 08:42 PM
Brandon Wittmer
Dec 20, 2014 09:51 PM
1LEThumper
Jul 14, 2003 12:45 PM
