Not good :(
Not good :(
well wednesday at the track i melted a bunch of plugs really really bad...so yesterday i put new ones in...and only marginal improvement occured...so i pulled the new plugs out for a compression test...7 of the cylinders were all reading 185 to 190 psi....then one of them only gave me a reading of 30 psi!! so i'm pulling that head off tonight to check and see if i melted a piston or a possible blown head gasket but 80% of the time a blown head gasket would cause more than 1 cylinder to bleed pressure like that...anyways i will have some result's by monday, because tonight is really the only time i will have to work on it...anyways..wish me luck lol,later
carter
carter
hey tim,
i had sex with your mom
well it turns out it was a broken exhaust valve..don't know how that happened lol...but the seat on the head is dinged up and the piston has nicks in it from the valve peices...oh well time for a new project anyways hehehe....callin up JPR for one of his 382 all bore short blocks and some mti stage 3 ls6 heads..with my new custom cam...should be pretty nice..anyways thanks for the support guys...exept tim the leader of the mid life crisis crew
later,
carter
later,carter
Magenta_Hearts
Mar 25, 2015 10:24 AM
IgorT.455/406
Mar 12, 2015 03:39 AM
Fbodfather
25
Jun 21, 2002 04:12 PM
