heater barely getting warm
Old Oct 2, 2006 | 03:04 PM
bond2's Avatar
Starting to get some cold days up north in Ohio and my heater has been blowing barley warm air when set on full heat. No leaks from the heater core and the blower is working fine. Any ideas or previous experience with heater issues? Any help is appreciated. I did a search and didn't find much. Thanks
Old Oct 2, 2006 | 03:11 PM
BUBBA's Avatar
Re: heater barely getting warm
Make sure your system is full. JMHO
Old Oct 2, 2006 | 03:17 PM
TobyZ28's Avatar
Unplug your water lines that go to/from the heater core. Hookup a hose to them and flush, then flush in the opposite direction. Alternate a couple of times. Hook it all back up and (hopefully) enjoy heat once again
Old Oct 2, 2006 | 03:44 PM
sleeperMULLET's Avatar
do you have a 160 t-stat, mine would never get warm on cold days when I had the 160 in
Old Oct 2, 2006 | 04:06 PM
Flushing the heater core, as suggested above, is usually the fix for this common problem.
Old Oct 2, 2006 | 04:23 PM
Dennis93TA's Avatar
I had an old school thermo in mine and it would never get hot. Got a 160 now for the lt1 and have plenty of heat.
Old Oct 4, 2006 | 08:31 PM
bond2's Avatar
I'll try flushing it out as you guys have suggested. Probably just build up. My ride does have 150k on it. I'll keep you posted on the result. Thanks
Old Oct 4, 2006 | 09:20 PM
reamo04's Avatar
i have the same problem, im gonna try buying a new thermostat since i need one anyways.
Old Oct 5, 2006 | 08:23 AM
Red95M6Z28's Avatar
With a 160 thermo it will never blow heat. Ran into that problem myself.
P.S. That black Ws6 is super sexy.....mmmm
Old Oct 5, 2006 | 01:55 PM
94Camaro_Z_28's Avatar
Flush the system and it should work like new.
Old Oct 5, 2006 | 05:11 PM
Lt1 and Ls1's Avatar
Not trying to change the subject, but I just had to read this thread because it is still SUPER HOT here
Old Oct 5, 2006 | 05:19 PM
razor02097's Avatar
If you flush the heater core don't get the opti wet
Old Oct 29, 2006 | 05:57 PM
bond2's Avatar
Finally some heat
Guys, your all brilliant. Finally found the time to flush out the heater core. Took some serious pulling to get those 11 year old hoses loose! flushed it with my garden hose, both sides, reconnected the hoses and clamps, fired the beast back up. Within a minute I started to feel some warmth. Once the car was at normal operating temp I turned up the blower and I don't think I have felt air that hot since 1996. You guys are the bomb.
magman
Apr 15, 2016 03:08 AM
David Dempsey
Mar 12, 2016 12:42 AM
PopoFormula
Oct 12, 2015 04:19 PM
Fatdog2
Sep 16, 2015 11:04 PM
tdigger9899
Sep 7, 2015 10:56 AM
