k-member
Old Sep 24, 2006 | 01:34 AM
ROUDA's Avatar
k-member
I need to know if the k-member on a v6 is the same as a v8 and or if the motor mounts are different how do you change the v6 mounts to hold a lt1.
I am going from a stock 3.4 v6 k-member to an lt1 kmember cause I an doing the lt1 swap in the car and I am just getting the k-member off the lt1 and useing all the other parts off the v6 such as spindles and brakes rotors , but if I dont have to do anything besides switch the mounts it would be easier than putting everything on the v6 k-member to the lt1 k-member.
Old Sep 24, 2006 | 09:23 AM
AlfredB18's Avatar
Re: k-member
You need LT1 mounts and k-member. They are specific to the engine.
So, in a sense, that is easier. Swap LT1 K-member and mounts into the v6 car and be done with that part.
Old Sep 24, 2006 | 10:47 AM
ROUDA's Avatar
Re: k-member
so what your saying is you can put the lt1 k-member in then v6 k-members place without alot of trouble.
97blackformula
Aug 27, 2015 06:02 PM
Sniper33
Aug 5, 2003 09:53 AM
speedmiser
May 28, 2003 12:23 PM
Ucantcme57
3rd Gen / L98 Engine Tech
13
Oct 23, 2002 08:39 AM
ShaneS
West South Central
Sep 11, 2002 07:48 AM
