k-member
I need to know if the k-member on a v6 is the same as a v8 and or if the motor mounts are different how do you change the v6 mounts to hold a lt1.
I am going from a stock 3.4 v6 k-member to an lt1 kmember cause I an doing the lt1 swap in the car and I am just getting the k-member off the lt1 and useing all the other parts off the v6 such as spindles and brakes rotors , but if I dont have to do anything besides switch the mounts it would be easier than putting everything on the v6 k-member to the lt1 k-member. |
Re: k-member
You need LT1 mounts and k-member. They are specific to the engine.
So, in a sense, that is easier. Swap LT1 K-member and mounts into the v6 car and be done with that part. |
Re: k-member
so what your saying is you can put the lt1 k-member in then v6 k-members place without alot of trouble.
