can't decide between two cams. HELP!
Old Sep 22, 2006 | 03:35 AM
mvvette97's Avatar
I'm going to get one of these two. They are both Comp. Cams..........228/230 @.050 571/573 lift 112LSA PT# 54-428-11 or this one....224/228 @.050 534/537 lift 112LSA PT# 54-418-11.......... Will the smaller cam have the lope that we all like? I figured you guys have heard about all the cams out there so what do you think. I have an M6 so I don't have to worry about a stall.
Old Sep 22, 2006 | 07:24 AM
Specialized's Avatar
Re: can't decide between two cams. HELP!
The 224/228 is a bit smaller cam, but will still have the lope you want.. although it wont be very crazy. The larger one(228/230) will be an EXCELLENT daily driver, while keeping lift under .6 and still haveing a nice lope along with great power under the curve. (read: nice torque all over, will pull nicely to 6300++)
Old Sep 22, 2006 | 08:34 AM
SSpdDmon's Avatar
Yeah, get the 228/230. Just make sure you have the bolt-ons to support a cam.
Old Sep 22, 2006 | 09:24 AM
Bayer-Z28's Avatar
I don't really see anything too eye catching about the second cam. All you'd really get out of it except a wicked overlap and maybe 25 hp.....I'd do the second one, more lift...not insayne, but more lift and duration...
What other Valvetrain components are you looking at to install w/ it? Springs, Rods?
Old Sep 22, 2006 | 10:08 AM
mvvette97's Avatar
yea springs and pushrods. Can i use the stock length pushrod with these cams or do i need a differant length?
Old Sep 24, 2006 | 10:10 PM
GhostZ28's Avatar
stock legnth are fine, as long as you dont start to mess with the rockers and such. Be sure to replace them though with some hardened rods.
Old Sep 24, 2006 | 10:27 PM
mvvette97's Avatar
Aren't the stock length Comp cams pushrods something like 7.4 or something like that?
Old Sep 25, 2006 | 05:15 AM
AL SS590 M6's Avatar
Moderator
yes stock is 7.400" You need to find out if the cam has the stock base circle. If it uses the stock base circle the stock length pushrods are what you need. If the cam has a smaller base circle the the pushrods need to make up the difference. Example: if the BC were .050 smaller than stock you might need 7.450 pushrods.
magman
Apr 15, 2016 03:08 AM
David Dempsey
Mar 12, 2016 12:42 AM
Bxlt1
Sep 29, 2015 03:18 PM
GusarskiSS
Exhaust System
Sep 2, 2015 03:51 PM
