Lingfelter oil pumps...
Old Sep 21, 2006 | 03:10 PM
SSCamaro's Avatar
anyone have one for can give feedback on them? Are they any good?
Old Sep 21, 2006 | 03:34 PM
GhostZ28's Avatar
Re: Lingfelter oil pumps...
i dont know anything from him that isnt good
Old Sep 21, 2006 | 03:51 PM
SSCamaro's Avatar
Thats what I was thinking, but, I have not heard of anyone having one, which makes me curious as to its performance, seeing as I can get one on the cheap, well, for like $101.00 to my door.
Old Sep 21, 2006 | 11:57 PM
AL SS590 M6's Avatar
Moderator
An oil pump is like a lid. They're all about the same. Some vendors open them up and polish out any casting flash and call them "ported". Katech and some others use a non-stick coating on the pumps to help promote flow.
A bone stock LS1 pump does the job just fine so any improvements from there are fine.
Old Sep 22, 2006 | 07:55 AM
SSCamaro's Avatar
Hmmm, interesting, thanks.
Old Sep 23, 2006 | 07:44 PM
Kwiksilverz28's Avatar
What on the 98 pumps failed? I believe that is a concern....
Old Sep 24, 2006 | 05:52 AM
Moderator
The pressure relief valve bore in some pumps was rough and the piston would stick in the open position dumping too much oil right back into the pan causing oil starvation.
Old Sep 24, 2006 | 09:04 AM
Shall I assume by 50k miles if it has not failed it is not going to?
Old Sep 24, 2006 | 01:17 PM
SSCamaro's Avatar
I would think not nessisarily. If your plunger never hit the sticking point, then, one cold day does................. bye bye...
Old Sep 24, 2006 | 01:26 PM
That is what I figured. Guess that is on the list when I do the cam...
Old Sep 24, 2006 | 09:45 PM
GhostZ28's Avatar
A ported pump should be on the list for any mild-agressive cam install anyway
Old Sep 25, 2006 | 10:54 AM
SSCamaro's Avatar
at least a high volume pump, anyways....
RX Speed Works
Jul 24, 2015 02:25 PM
big_mac421
Jul 13, 2015 03:48 PM
jl1ne
Jul 7, 2015 08:38 PM
streetbad
Advanced Tech
Jul 5, 2015 10:40 PM
SergheiS
Jul 5, 2015 03:27 AM
