clanking from under car
Old Nov 13, 2002 | 04:10 PM
robz71&00sS's Avatar
I have noticed our SS making a metal to metal clunk sound when I drive over bumps. I seems to b coming from right behind the drivers side door. We have sfc's installed and thats all. Could something have popped loose. I looked underneath and didn't see anything haning down but the noise sounds like something loose and smacking the frame or body when drive over bumpy roads or potholes ect. Any help?
Old Nov 14, 2002 | 10:37 AM
ttt
Old Nov 14, 2002 | 10:41 AM
My84Z's Avatar
Have you retightened the bolts since you put them on? You should every so often. i would check that first and move on from there.
Old Nov 14, 2002 | 10:43 AM
Thanks for the help 84 but I should have mentioned they are weld in sfc's.
Old Nov 14, 2002 | 10:52 AM
My84Z's Avatar
since they are weld in a would check all the bushings with the new stifness the junky rubber stock bushings will take a big dump on ya. especially check the lower control arm bushings. hope i am helping.
Old Nov 14, 2002 | 10:54 AM
I will check thoes, I had not looked into that yet. thanks
Old Nov 14, 2002 | 01:00 PM
My84Z's Avatar
also check the tourque arm
Old Nov 14, 2002 | 06:48 PM
Smitty01Z28's Avatar
I have the same clunking. Its almost like someone is draggin a 1/4 inch thick rod under the car. I have had it since I got my car with 2,000 miles on it. I havn't found the problem but it also makes noise whenever I release the clutch to start to move. It has somewhat gotten worse now tih 17,000 miles. Oh well, If I have time I will take it in to get it fixed.
joN
Old Nov 18, 2002 | 02:36 AM
TerrorDome's Avatar
my car makes that noise too or something close, and i will have to jack it up and make sure nothing's loose..
Old Nov 18, 2002 | 07:27 AM
My84Z's Avatar
so did anyone find anything?
Old Nov 18, 2002 | 09:09 AM
Well I found that the bolt that runs through my sfc and lca was a little loose so i tightened it up and presto no more clunk.
Jazsun
Dec 29, 2014 12:14 PM
1996LT1Z28
Middle Atlantic
Dec 4, 2014 09:37 PM
1996LT1Z28
Dec 4, 2014 09:20 PM
USAirman93
Nov 24, 2014 03:37 PM
