LCA/bracket question
Old Aug 23, 2006 | 11:08 AM
BLDun's Avatar
I lowered my car some time ago and no problems with vibration. Recently I got around to having relocation brackets welded on and I installed adjustable lca's. Now when I hit 80 it get some noticable vibration. The torque arm is stock so I don't the pinion angle is a problem. I spent 1/2 a day adjusting the rearend side to side and also making sure that the conrol arms were exactly the same. Any reason for the vibration other than the poly bushings?? I placed the lca's in the lowest holes on the brackets. Should I move them up to the next one and see if that helps???
Old Aug 23, 2006 | 07:39 PM
OBE1 95Z28's Avatar
Re: LCA/bracket question
LCAs shouldn't induce vibration. I'd double check that your adjustable LCAs are set to the stock LCA length.
Old Aug 23, 2006 | 07:54 PM
BLDun's Avatar
I have already disposed of the old ones. How do I know what the stock length is supposed to be?
Old Aug 23, 2006 | 11:30 PM
Dave '97 Z28 M6's Avatar
I just measured my LCA's... they're 19.25" between the centers of the mounting "holes".
Old Aug 24, 2006 | 12:14 AM
BLDun's Avatar
Thanks! I'll check mine tomorrow and see where it's at. Make any difference which hole it's in or do I just make the length right and then figure which hole it matches up to?? Which raises a thought. . . .what is the purpose of them being adjustable???
Old Aug 24, 2006 | 01:09 AM
00cls1camaross's Avatar
if your car is lowered throw it on the 2nd hole... if not put it on the first
poly bushing allow more road vibrations than the stock rubbers... you did have them greased right?
i just put on rubber/poly lcas and brackets and i didnt notice ****...
Old Aug 24, 2006 | 07:50 AM
BLDun's Avatar
It is lowered so I will move it to the second and try that. I will grease them good again also and see if that helps. Thanks
Old Aug 24, 2006 | 09:56 AM
The holes in the relocation brackets should be in an arc that allows a stock length LCA to use either hole. You can use the adjustment in the LCA's to locate the axle front to back, if necessary.
dluna333
15
Mar 13, 2015 12:30 PM
jasonduaine
Mar 7, 2015 09:44 AM
30thZ4C
Wheels and Tires
Jan 29, 2015 06:03 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
