D1 oil return.
Old Aug 22, 2006 | 07:42 PM
blown383's Avatar
D1 oil return.
Does anyone know off hand what the NPT thread size is on the Procharger D1 blower oil return bung? I'm looking to replace the oil return line to teflon hose since I have about 40 feet of it laying around.
-B
Old Aug 23, 2006 | 10:08 PM
mzgp5x's Avatar
Re: D1 oil return.
1/2 npt thread. I had to bush down to 3/8 for a -8male by 3/8npt 45* el. I have a Canton lt1 pan and ran it on the passenger side oil inlet. Some say this is bad, but it looks like it is working.
Old Aug 24, 2006 | 02:02 AM
blown383's Avatar
Re: D1 oil return.
Why didn't you go with a 1/2npt to -8AN male fitting then used either a 90 or 45 degree -8AN to the pan?
-B
Old Aug 25, 2006 | 08:01 AM
mzgp5x's Avatar
Re: D1 oil return.
There are two D1 outlets. I selected near the engine. I used -8 socketless hose from Summit with a straight barb. The straight fitting (straight 1/2npt to -8) and hose had interfearance with the front sway bar. A 45* fit better but I did not have a 45.x1/2npt (dont know if they make them. could not find.). Also, the inlet diameter to the fitting was the same as a 3/8 npt. So I bushed it. I only run the hose around the pan, then, to a -8 alum hardpipe --> pan. I guess a more direct (accepted) way is to make a hole in the front left pan and run it direct to a bung. They say they get better oil return that way.
RX Speed Works
Jul 24, 2015 02:25 PM
big_mac421
Jul 13, 2015 03:48 PM
jl1ne
Jul 7, 2015 08:38 PM
streetbad
Advanced Tech
Jul 5, 2015 10:40 PM
SergheiS
Jul 5, 2015 03:27 AM
