ATI Super Dampers ...
Old Aug 20, 2006 | 07:52 PM
bowtiepwr's Avatar
>Hey all,
is there anyway to maake this work with a Vortech S/C... ATI Super Damper's Supercharged Series
http://www.atiperformanceproducts.co...s/damsuper.htm
using either 918872E or 918873E
7.074"
probably make a good cog set up if it's usable.
Old Aug 21, 2006 | 06:52 PM
Sean94Z's Avatar
Re: ATI Super Dampers ...
ATI told me it will not work on an LT1 when I asked :'(
Old Aug 21, 2006 | 09:12 PM
bowtiepwr's Avatar
>did they say why it wouldn't work?
Old Aug 22, 2006 | 06:01 AM
Sean94Z's Avatar
LT1's use integrated balancer and pulley, this does not have the pulley grooves on it, only grooves for the supercharger pulley.
Old Aug 22, 2006 | 06:21 AM
bowtiepwr's Avatar
>so this damper would have to get connected to a LT1 hub anyway? kind of defeats the purpose of having one unit.
Old Aug 22, 2006 | 04:22 PM
Sean94Z's Avatar
You could not do that because you would need a balancer on the motor as well as this pulley. So, you would have the hub, a custom pulley, and then this balancer...
Old Aug 23, 2006 | 04:17 AM
bowtiepwr's Avatar
>I still don't see why this wouldn't work... there is a 2 piece process for the hub and balance and we attach the crank pulley to the balancer, but if the balancer was long enough then it would be just 2 pieces instead of 3.
I will contact them (I am missing something in translation).
Old Aug 23, 2006 | 07:51 AM
Sean94Z's Avatar
The LT1 balancer is BOTH a balancer AND a crank pulley. This ATI piece has no grooves in it to drive the alternator, power steering, a/c, etc. It only has the belt grooves to drive a supercharger.
Old Aug 23, 2006 | 08:23 AM
cjmatt's Avatar
the vortech is not run off the same belt as the accessories, so it will not work
Old Aug 23, 2006 | 04:28 PM
bowtiepwr's Avatar
>this damper has one pulley for the accessories drive and the other part is for the crank to blower and it attaches to the LT1 hub.
am I still not seeing it?
G-BODYT56
Jan 14, 2022 11:14 PM
Hal Fisher
Sep 30, 2015 09:03 PM
MDZ28
11
Sep 24, 2015 09:15 AM
Daluchman1974
Sep 11, 2015 06:12 AM
