96' A4 2.73's - Won't downshift at WOT
Old Aug 16, 2006 | 11:47 AM
EuroticCustoms's Avatar
I've been chasing problems with this car since I got it. Had to work out bugs in the ignition and fuel system...new opti, plugs, wires, fuel pump, etc.
Now, the car runs a LOT better, but it won't downshift if you're running over 2K RPM's in any gear. If you're running under 2K and push the gas all the way, the car downshifts and takes off.
I'm thinking detent/kick down cable needs adjusted, but? The tranny was rebuilt and has a shift kit. This was before I bought it, so I don't know much about the tranny.
Any suggestions?
Old Aug 16, 2006 | 11:56 AM
Moshbmx1's Avatar
Re: 96' A4 2.73's - Won't downshift at WOT
Can you pull it down to gear manually?
Old Aug 16, 2006 | 12:27 PM
Yeah. The shift gate has been modified so that the transmission can be manually put into 1st also. I can downshift it all day long, but it won't kick down on it's own above a certain RPM. Also have a Hypertech Power Programmer, but haven't messed with the shift points. Might do that later. I want to change the tranny fluid and filter before I get too crazy though...I've got synthetic fluid to go in.
Old Aug 16, 2006 | 12:29 PM
i'm also wondering if maybe when the last tranny was put in if they re-adjusted the detent cable. I'm gonna go try that before anything else.
Old Aug 16, 2006 | 04:39 PM
12SCNDZ's Avatar
Um...'The '93 F-Body is the only 4th gen with a TV cable. '94-'02 are electronocally controlled. You may have something stuck in the valve body, or possibly a throttle postion sensor.
Are you getting any "SES" lights?
To properly diagnose it, I'd have to drive it with a scanner on it to watch the data parameters.
Frank
CPT
Old Aug 31, 2006 | 09:42 AM
96LT1MD's Avatar
I have the same exact problem with a 1996 Caprice with an LT1 with the same exact modifications. Any answers to the initial question will be helpful in my case as well.
PopoFormula
Oct 12, 2015 04:19 PM
68camaroboltz
Oct 5, 2015 01:46 PM
Hal Fisher
Sep 30, 2015 09:03 PM
KYWes
Sep 26, 2015 08:49 AM
SEOJustin
Sep 24, 2015 04:39 PM
