2 bar MAP program
Old Aug 13, 2006 | 09:51 PM
creed1062002's Avatar
2 bar MAP program
I edited a program for a 2 bar, and now something is not right the car will start and die about 10 seconds later. Any ideas?
Old Aug 14, 2006 | 04:00 PM
cjmatt's Avatar
Re: 2 bar MAP program
you must not have edited it right does it work in speed density mode?
Old Aug 14, 2006 | 08:58 PM
no it doesn't work at all SD or MAF
Old Aug 15, 2006 | 08:53 AM
cjmatt's Avatar
why dont you put it back to a 1 bar program and see if itll run
Old Aug 15, 2006 | 10:07 AM
Bryan 94 Z28's Avatar
That's what I was going to suggest also. If it doesn't run, then maybe you accidentally changed something else in the program that is causing it to cut off.
Does it smell like it is loading up on fuel and then stalling? Or is it running normally and then just cutting off abruptly?
Old Aug 17, 2006 | 08:44 PM
it only runs about 10 seconds with the 2 bar program and then the injector pulse width goes to 0 and dies. runs fine with the 1 bar other than the other problem i can't figure out see other post.
revrider
Cars Wanted
Apr 5, 2016 10:06 AM
football4life
Oct 4, 2015 07:48 AM
SEOJustin
Sep 24, 2015 04:39 PM
MDZ28
11
Sep 24, 2015 09:15 AM
tdigger9899
Sep 7, 2015 10:56 AM
