tire pressure
Old Aug 11, 2006 | 10:35 AM
jhthornley's Avatar
tire pressure
probably a dumb question, but here goes anyway..
Getting a new set of 17" 275s (on Z06s).
Swapping over from stock salad shooters (16" 245s) on a 95 Z28.
What tire pressure should I set them at for a daily driver to get even wear etc..??
thx
John T
Old Aug 11, 2006 | 05:18 PM
Re: tire pressure
Use the tire pressure recommendation on the sticker on the door. I had good luck with the 275/40-17's in the 32-36psi range. Vary the pressure to see which pressure gives you the best combo of traction, resistance to wandering in road ruts, and cornering. Check the tread with a tread depth gauge periodically to make sure the wear is even across the full width of the tread.
Old Aug 12, 2006 | 08:08 PM
jhthornley's Avatar
Re: tire pressure
word.. thx..
I figured it'd be basically the same as the 245s, (I run 34-35 psi) and have been satisfied w/ the results.
JT
RichJ
Sep 14, 2002 09:37 AM
Frank95z
Sep 10, 2002 08:30 PM
97bowtie
Aug 25, 2002 11:00 PM
Cap'n
Aug 19, 2002 11:33 PM
wytblur
Aug 5, 2002 02:03 PM
