zex
Old Aug 10, 2006 | 12:28 PM
fbodyboy's Avatar
zex
what is your guys opinion of the zex kit. I can get a used one for about 300. Is it worth it or should i just save and get a better one?
Old Aug 10, 2006 | 12:38 PM
01Z's Avatar
01Z
Re: zex
I like mine but it is far from what the (wet) kit came originally. It's compact under the hood. If you mount it up like I did you won't have solenoids here and there and -3 an lines crisscrossing the engine, if that even matters. Now for a fresh barrage about cheap little solenoids....
BTW, if you can install that kit in 2 hours or so, please tell me.
Old Aug 10, 2006 | 01:29 PM
jldak318's Avatar
Re: zex
the only problem with the zex kit is it only can flow up to 125. from what i hear.
Old Aug 11, 2006 | 01:32 PM
MILESF's Avatar
Cool Re: zex
I love mine. I have the 125hp jets in right now. Best bang for the buck for a dry kit.
Fred
Old Aug 11, 2006 | 09:41 PM
fbodyboy's Avatar
Re: zex
Fred
Did you have to run anything else in combination with it? Like a aftermarket fuel pump, different plugs, retard the timeing and things of the such. 125 shot is exactly what i wanted to run.
Old Aug 11, 2006 | 11:07 PM
jasonisdn's Avatar
Re: zex
should have a in-line pump with it , if not get 1. change plugs , go down 1 or 2 ranges colder, gap at 35. then dont spray it untill you get it on a dyno to make sure your not getting to lean. i know it watches the fuel pressure and is supposed to add more with more vac, but my car was running lean on the 125 and i actually had to max the injectors out. not a wise thing to do but i was hoping to blow it up to make the rebuild happen sooner. well off to the river to do some tubing, later
Old Aug 13, 2006 | 09:20 PM
fbodyboy's Avatar
Re: zex
Thanks for the advice, i was going to put a full racetronics pump kit with it, and also put bigger injectors with it, so i think i'll be good. I'm currently running a colder plug right now, but was going to switch to the ngk's. I also planned on putting the car on the dyno anyways, so i guess it all kinda works out.
100kstockLT1
N2O Tech
Sep 28, 2003 09:23 PM
6spdz28
N2O Tech
Sep 7, 2003 11:51 PM
Black96WS6
N2O Tech
Jun 29, 2003 09:42 PM
Black96WS6
May 17, 2003 06:17 PM
93 LT1
N2O Tech
May 3, 2003 03:18 PM
