Replaceing fuel filter (questions)
Old Aug 3, 2006 | 08:29 PM
Šenial™'s Avatar
I think its time to replace the fuel filter asap, i have an 84' its only been mine for 2 years now but in that time i havent replaced it and i dont know when the last time it was if ever, its starting to feel real sluggish and doesnt want to fire up sometimes now also, just spinning but getting no gas if i leave it sit a few hours itll start right up, so im going to replace it and see what happens.
My questions are, where exactly is it located, i know its on the bottom of the car but instead of trying to follow the gasline the whole way from the tank to the front (im pretty sure its somewhere up front) i figured id ask to get a general idea to start out at.
Also, is it required to get the car on a lift or could i just get it high enough off the ground to get a creeper under it?
Finally, a buddy was saying they make "high preformance" filters, what exactly is the difference in them and regular autozone bought filters and is it worth the extra money? I didnt even know they existed until he told me they did, so can anyone confirm they even exist? thanks...
Old Aug 3, 2006 | 11:00 PM
Craddock's Avatar
Re: Replaceing fuel filter (questions)
One my buddy's 87 Trans Am it's in front of the back wheel on the driver side if I remember correctly. We changed it by just jacking it up. Yeah they make high performance filters, I've never used one, but it couldn't hurt. You've done a lot of work to your car from your sig so it might be worth the extra cash. I think you can even get ones that you can clean, I may be wrong about it.
Old Aug 4, 2006 | 01:04 PM
Šenial™'s Avatar
Thanks man, if i can find one that i can clean that would be real nice.. as it sits over the winter and i believe thats when the corrosion and other stuff builds up in the filter after sitting awile.. that would solve my problem all together and a few bucks at the same time
Old Aug 8, 2006 | 03:50 PM
Logicc's Avatar
http://www.r6messagenet.com/forums/s...39#post1160239
Still out scamming I see.
Old Aug 8, 2006 | 09:23 PM
Šenial™'s Avatar
you are hilarious man.. you join a forum just to cause trouble, im not saying that im sure some people get off on that but you do it more souly for the purpose to stalk somebody, not only has it already been prove that i am not that guy, but the guy that did do all that has been put to justice
Old Aug 9, 2006 | 03:32 PM
Mighty's Avatar
How has it been proven that you aren't the guy? I'd like a link, please.
Old Aug 10, 2006 | 08:38 AM
JakeRobb's Avatar
Super Moderator
+1
Why don't you just leave? Whether it's true or not, enough people believe that it's true that you're never going to get any credibility or respect on this board.
Old Aug 11, 2006 | 09:24 PM
Blue89Bird's Avatar
go away scammer
http://web.camaross.com/forums/showthread.php?t=465456
Old Aug 11, 2006 | 10:20 PM
Fire's Avatar
I've never heard of a "high preformance" fuel filter, although i did replace my stock corroded one with a nice thick glass one so you can see right into the filter part and see whats going on, it said on the box its "lifelong" guess ill find out
Old Aug 13, 2006 | 02:57 AM
bunn_69's Avatar
if the car has a Rochester Quadrajet carb then the fuel finter will be in the carb where the fuel line goes in. what i have done to my 1986 Z28 Camaro was bought a 3/8" fuel fittings from carquest, a stright and a 90 degree fittings and got 3/8" fuel like and a chromed fuel filter with a reusable element in it so it can get better fuel flow over stock. also if its a quadrajet the stock fuel filters are made out of paper.
PCLZ28
Dec 24, 2015 05:19 PM
Jazsun
Dec 29, 2014 12:14 PM
30thZ4C
Dec 26, 2014 05:09 PM
Jul 4, 2005 05:00 PM
supercharged94Z28
Feb 24, 2003 10:22 PM
