Spohn LCA loud as HE!!
Old Jul 31, 2006 | 02:30 PM
deadmeat2004's Avatar
Just bought some double adj. LCA's and they are loud as crap. every small bump i hit they make a lot of noice. I went under the car again and made sure that the rod ends lined up nicely in the center of the brackets. the drivers side is not that much louder than stock, but the pass. side is going to drive me crazy! What could it be if just one side is making the noice?
Old Jul 31, 2006 | 02:51 PM
RE AND CHERYL's Avatar
Re: Spohn LCA loud as HE!!
Nothing really. LCAs with rod ends make noise. But not usually right away. You probably got a bad rod end or two.
Old Jul 31, 2006 | 02:54 PM
IgorT.455/406's Avatar
When installing, what is the best thing to do and use to lube the rod ends?
I installed my adj. poly/rod combo, but haven't put the rear end back into the car yet. Just wondering what to do when I do.
Thanks.
Old Jul 31, 2006 | 02:55 PM
Thanks.
what does that have to do with what I asked....
Old Jul 31, 2006 | 03:05 PM
Bayer-Z28's Avatar
Tightened up all the way? I installed Hotchkis LCA's a number of years ago and I've never had a problem w/ them.
Old Jul 31, 2006 | 03:35 PM
Hmm, a) so we would all know, and b) perhaps you installed them "dry" when you should not have (don't know for sure, hence why I asked), and c) prevent starting a new post on the same subject.
On my '88 I have poly LCA but rod end PHR and I noticed no major noise with the PHR. I used "chassis grease" on them when I installed them.
Old Jul 31, 2006 | 04:34 PM
its called stealing my thread. what i asked has little to do with what u asked.
Old Jul 31, 2006 | 04:35 PM
so back to the double adj. rodended, nothing should be causing it to make noise only on one side that anyone can think of?
Old Jul 31, 2006 | 06:19 PM
jdhommert's Avatar
Did you buy them new or used?
If installation is correct, i'd bet that you've got a bad rod end.
Old Jul 31, 2006 | 07:45 PM
Severous01's Avatar
did you use spacers for the bolts?
rod ends are noisey any way, a lot more than rubber. expecially if you connected them to the car with rod ends. i'd take that connection off and buy either polly or rubber bushings to insert there. i did that and i have absolutely no more noise than normal but much better performance.
rod ends shouldnt be lubed with anything but the race they came in. they dont need lube at all...and actually that will cause them to wear faster. it's a huge dirt collector(oil and grease).
Old Aug 1, 2006 | 11:21 AM
I have the Spohn adjustable LCA's with the rod ends, and they don't make any more noise than you would expect a rod end to make.... nothing that's annoying or audible over the very loud exhaust.
When you mentioned checking that the rods ends are "lined up nicely in the center of the brackets".... what did you mean? The rod ends are "centered" in the brackets by the ferrules that come with the LCA's. Are you sure both the bolts you are using on the noisy side are the correct diameter for the sleeve in the rod end? Did you torque the bolts to spec?
RUENUF
Mar 13, 2016 03:37 PM
Henson071
Dec 30, 2015 09:55 PM
Henson071
Sep 18, 2015 04:01 PM
Matt Dreessen
Sep 9, 2015 09:58 PM
Boss002
Jul 24, 2015 10:47 AM
