failed program
Old Jul 30, 2006 | 09:53 AM
1BLK97CONV's Avatar
failed program
i was using my hyper-tech and midway thru program it quit.now car won't start,programmer won't connect.called hyper-tech no help there.so is there anybody out there that can fix these two problems?
Old Jul 30, 2006 | 11:34 AM
turbo_Z's Avatar
Re: failed program
Easy fix for the hyperjunk is to throw it in the trash... seriously.
The PCM however is a little tricky. You have to send it off to somebody like madwolf to have it fixed. Or you could try to find one on ebay.
Old Jul 30, 2006 | 01:12 PM
madwolf's Avatar
Re: failed program
I may be able to fix both. The PCM for sure though. Were you trying to use the Hypertech over the custom tune? It would have probably overwritten it anyway.
Old Jul 30, 2006 | 02:10 PM
1BLK97CONV's Avatar
Re: failed program
no i have 2 pcm's 1 from you and a stock one.the stock one is the half programmed 1.have no idea what happened.it just quit.
Old Aug 5, 2006 | 06:21 PM
blk97ta's Avatar
Re: failed program
try unhooking the battery ! for 5 minutes . then try to program it again
Old Aug 6, 2006 | 03:16 PM
jonota's Avatar
Re: failed program
If the hypertech won't connect and the computer won't run the car, you erased the EPROMs and didn't write the tune back to it. This can happen anytime you lose power while programming. I ALWAYS make sure I have good connectivity prior to programming by reading at least once. If you have a weak battery, DO NOT ATTEMPT it.
That being said, on OCCASION, resetting everything can fix it. It's highly improbable though. Usually you need a new computer. Use the other one you have. The hypertech is probably now useless, as from now on it will think you are trying to program someone else's car. Hypertech USED to allow you to send it back and get it fixed for a nominal charge. I would ONLY recommend doing this if you plan on selling it to some other unsuspecting soul through ebay or the like.
Jonota
Jeff1904
Jun 5, 2016 05:00 PM
revrider
Cars Wanted
Apr 5, 2016 10:06 AM
MDZ28
11
Sep 24, 2015 09:15 AM
marlar98
Sep 19, 2015 07:53 AM
damnyankee36
Sep 9, 2015 07:06 PM
