how to tell....
Old Jul 19, 2006 | 01:03 PM
TheZfor-me's Avatar
how to tell....
how do u tell if you have an aftermarket MAF sensor or throttle body on a 2001 Z28
Old Jul 19, 2006 | 01:43 PM
SSpdDmon's Avatar
Re: how to tell....
They look different than stock. Now, if someone modified stock parts (i.e. home port the tb or descreen the maf), you can't tell unless you take it apart and peak inside. Most companies like to put their brand on their products though. If you have a BBK throttle body or an SLP MAF, it'll be obvious.
Old Jul 19, 2006 | 02:38 PM
teke184's Avatar
Re: how to tell....
stock on the left...75mm wide...and aftermarket 85mm unit on the right
here is my ported TB...you can see a smooth transition from the sloped front, to just a flat inner bore. there is typically a lip just in front of the blade (when closed).
here is a drawing i did on how it helps...it may explain it better
RustyRodder
Oct 24, 2007 10:10 PM
93yellowta
May 19, 2007 09:52 AM
Javier97Z28
Feb 14, 2006 11:12 AM
gto*johnny
V6 Tech
Feb 27, 2005 11:40 PM
JustAnotherT/A
Sep 11, 2003 06:47 AM
