ATF fluid & filter change
Old Jul 14, 2006 | 08:15 AM
bt95formula's Avatar
How many quarts do I need to change the fluid by dropping the pan?
Old Jul 14, 2006 | 12:13 PM
01Z's Avatar
01Z
Re: ATF fluid & filter change
About 4 and perhaps a little more.
I left my pan off for 24 hours and somehow ended up draining a couple quarts extra. Perhaps a small drain off via small opening in the TC. But 4 - 5 quarts is what I remember from my other 4L60E.
Adding more than you asked, you might consider disconnecting the output line and pumping out a few more quarts. What I do is collect it, then measure what came out in order to replace the quantity exactly.
Old Jul 14, 2006 | 12:30 PM
I haven't really looked at the cooler lines but which one is the input to the cooler and which is the output to the trans?
Never Mind- Thank you for your reply. I found which lines are which in a cooler install. Thanks again
PCLZ28
Dec 24, 2015 05:19 PM
95z_28_camaro_4_Ivan
May 8, 2015 09:56 AM
VF-124
Mar 16, 2015 08:14 PM
David Dorris
Jan 17, 2015 08:10 PM
30thZ4C
Dec 26, 2014 05:09 PM
