Door handle question!!
Old Jul 13, 2006 | 01:51 PM
94_camm's Avatar
Ok i went to go open my car last nite n the outside door handle wouldnt open.i guess the rod or sumthing came off of the handle??the inside handle opens the door fine.so is thier anyway i can fix it myself?how do i get in thier?
-95 camaro
Old Jul 13, 2006 | 01:56 PM
MyShibbyZ28's Avatar
Re: Door handle question!!
I had this happen too, and wish I would have taken a picture.
Take the door panel off (yes, you have to), and look at the handle. There is a little arm extending off it on one side, and there is a rod that goes from the lock to that arm. The bent portion that goes into the hole on the arm is what slid out. You may have to bend it more so it stays in there, otherwise it will fall out if the car is slammed, or parked on a hill.
Old Jul 13, 2006 | 01:59 PM
TraceZ's Avatar
Shoebox!
Old Jul 13, 2006 | 02:00 PM
94_camm's Avatar
Your the man!!! ill fix it up later tonite n let you now how it worked out
Old Jul 13, 2006 | 02:01 PM
Well you can't see the arm on the handle in that picture, but that small rod with the threads on it is what you are looking for.
Old Jul 13, 2006 | 02:02 PM
TraceZ's Avatar
You dont bend the arm. There is a plastic clip on the end that holds it in. Maybe the clip on yours is broken?
Old Jul 13, 2006 | 02:03 PM
Mine never had a clip, and never had a spot to put a clip. It was just bent over so it would sit in the hole. It does not look like someone did it on their own either, looks factory done kind of. Either way, I have it fixed now.
Old Jul 13, 2006 | 02:05 PM
TraceZ's Avatar
Mine never had a clip, and never had a spot to put a clip. It was just bent over so it would sit in the hole. Either way, I have it fixed now.
Yeah yours must of broken and fallen out then. It is a plastic ring with a hook protruding from it. The end of the rod goes through it, then you put the rod through the door handle and to secure it you rotate the plastic clip around until the hook snaps over the rod.
Old Jul 13, 2006 | 02:07 PM
Interesting. I will have to investigate it, and see if it fell off or something. I just ended up bending mine a little more so it would sit there without falling.
Patricklt1
Apr 24, 2015 06:29 AM
sscott
Jan 17, 2015 04:30 PM
Caps94ZODG
Aug 18, 2002 07:02 PM
guionM
Jul 21, 2002 04:38 PM
