Electric water pump
Old Jul 10, 2006 | 04:07 PM
mook99TA's Avatar
Electric water pump
My pump is starting to leak at the seem and I know its gonna blow soon. Is anyone running an electric pump on their ls1 and what brand are you using? Also how reliable are they for a daily driver?
Old Jul 10, 2006 | 04:22 PM
teke184's Avatar
Re: Electric water pump
as far as i know...meziere is the only company that makes them.
and due to the price...not many are running them
contact angela...350 hrss...i am pretty sure she has one.
Old Jul 10, 2006 | 05:04 PM
mook99TA's Avatar
can't find here do you have her exact address
Old Jul 10, 2006 | 09:00 PM
AL SS590 M6's Avatar
Moderator
I've been running a street version Meziere on my 00 Formula for the past 3 years. Works great but I do not daily drive the car so I can not attest as to the longevity in that scenario. It will cool the motor much better than a stock pump at low rpms because it's always turning the same speed.
Old Jul 11, 2006 | 03:18 PM
teke184's Avatar
profile
Old Jul 11, 2006 | 03:23 PM
4U 2 NV's Avatar
thought CSI made one
Old Jul 11, 2006 | 03:26 PM
4U 2 NV's Avatar
well cant find one...get ready to shell out some coin..most are in the 550 range..the race ones are like 400 but not recommended for DD use. if i remember correctly a new AC Delco one is only about 90 bucks or so.
Old Jul 12, 2006 | 09:14 PM
toegead93's Avatar
CSI is now CSR. I have had my CSR for 1 1/2 years and it is great. No problems, I drive everyday and have taken long road trips. I'm very happy with it.
Old Jul 13, 2006 | 01:08 PM
cjmatt's Avatar
has anyone driven an electric waterpump car in the winter? id be curious as to how the motor operated around 20 degrees or so.
Old Jul 13, 2006 | 04:01 PM
mook99TA's Avatar
does CSR make one for a LS1 thought they only had them for LT1's?
Old Jul 13, 2006 | 07:12 PM
teke184's Avatar
"has anyone driven an electric waterpump car in the winter? id be curious as to how the motor operated around 20 degrees or so"
the motor will run as cool as the thermostat allows. the stat should restrict the water flow enough to maintain the temp about 10deg over the setting for the stat.
and as far as i know..unless you did some dedicated race pump that is a custom install....Mez is the only company that has the LS1 application right now....and it's $550+
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Stay Puft
Apr 20, 2015 06:24 PM
Queens94z28
Dec 20, 2014 09:11 PM
Zone
Jul 29, 2002 07:43 PM
