What's the diff between a 93 and a 97 t-56
Old Jul 9, 2006 | 02:05 PM
jcmz28's Avatar
i am rebuilding my t-56 out of my 97 camaro and I have a spare t56 out of a 93 i wanted to use while the other one is being rebuilt .... what is the diff between the 93 over the 97 besides gear ratio ..... can i bolt it in with out any problems ?
Old Jul 10, 2006 | 04:50 PM
Re: What's the diff between a 93 and a 97 t-56
Should be a direct bolt in.
93:
-no skip shift
-lower torque capacity rating
-different gear ratios
-actually two different versions
----M28 (93) ----M29 (93) ---- MM6 (94 and up
torque - 360 lb-ft - 400 lb-ft --- 450 lb-ft
rating
1 ------ 3.36 ----- 2.97 ---- 2.66
2 ------ 2.07 ----- 2.07 ---- 1.78
3 ------ 1.35 ----- 1.43 ---- 1.30
4 ------ 1.00 ----- 1.00 ---- 1.00
5 ------ 0.80 ----- 0.80 ---- 0.74
6 ------ 0.62 ----- 0.62 ---- 0.50
Axle --- 2.73 ----- 3.23 ---- 3.42
Old Jul 30, 2006 | 04:14 PM
Fast Caddie's Avatar
Isn't there a difference in the speedo sensor? I thought the '93 trannies needed some modification for the speedo to work in a 94+.
Old Jul 30, 2006 | 05:28 PM
94Camaro_Z_28's Avatar
I thought it was bolt in....only diff I know of was the ratios.
G-BODYT56
Jan 14, 2022 11:14 PM
revrider
Cars Wanted
Apr 5, 2016 10:06 AM
Henson071
Dec 30, 2015 09:55 PM
95z_28_camaro_4_Ivan
Aug 25, 2015 03:59 PM
realistyc
Jul 28, 2015 07:32 PM
