Just bought my LS1, questions on cam.
Old Jun 27, 2006 | 01:32 AM
drewstealth's Avatar
Well I just bought a 2002 Z28. The car is beautiful. I have missed my old Camaro ever since I sold it so I had to get another one. I'm familiar with all the mods on the car except the type of cam in it. It is a custom ground cam. The specs on it are 228/288 588 lift on a 112 LSA. Anybody know about that cam? What type of cam is it?(NA, supercharger, nitrous?)
It makes good power, it was dynoed at 385.5 rwph/ 376 rwtq. It drives real nice, except it is a bit rough in 1st taking off sometimes. It is pretty lopey also.
Old Jun 27, 2006 | 06:39 AM
teke184's Avatar
Re: Just bought my LS1, questions on cam.
TSP 228R camshaft
doesn't look particularly "custom" to me
should be a good N/A cam, somewhwere inbetween mild and big on the camshaft scale goes.
sounds like it produced good numbers.
Old Jun 27, 2006 | 10:07 AM
Greed4Speed's Avatar
It definately won't pass emissions in CA.
Old Jun 28, 2006 | 03:26 PM
mook99TA's Avatar
It may be a little rough in first if your still using the stock stall. Up it about 800 to 1,000 R's and you be loving it
Old Jun 29, 2006 | 06:24 PM
Well the car is a M6. I think it may be partly the cam, and the Spec stage 3 clutch.
Old Jun 29, 2006 | 08:39 PM
mook99TA's Avatar
true
Old Jun 29, 2006 | 08:59 PM
Specs are known to chatter.
Old Jun 29, 2006 | 10:19 PM
GusarskiSS's Avatar
I used to have a Mcleod Street Twin Setup with aluminum flywheel. I switched and put in the Spec Stage 3 setup with aluminum. Freakin' chatter. I already hate these clutches. MCLEOD is the best.
Old Jun 30, 2006 | 07:38 AM
AL SS590 M6's Avatar
Moderator
Did you break it in right? I have driven a car with a stage 3 and a stage 4 and both are as smooth as glass.
Old Jun 30, 2006 | 10:31 AM
GusarskiSS's Avatar
Yep. I broke it in right, that's for sure. The McLeod rules though, if you've ever tried one, you'll see the difference.
Old Jun 30, 2006 | 04:30 PM
Aklaim's Avatar
I can pass emissions with a very conservative tune.
Old Jun 30, 2006 | 06:17 PM
teke184's Avatar
wow...good for you...doesn't really help our discussion if you don't list the cam you're running.
Old Jun 30, 2006 | 11:44 PM
Aklaim's Avatar
Sorry that was a typo.... That should have read: It can pass emissions with a very conservative tune. In california, the TR224 cam passes with flying colors, without a special tune for smog testing. A 228 cam, with a special tune, should pass.
rideordie
Nov 5, 2019 04:52 PM
Sergio
Jan 27, 2016 04:27 PM
95chwagon
Feb 28, 2015 12:02 PM
Deadbolt24
Jan 19, 2015 01:29 PM
