Blew my rear end
Old Jun 27, 2006 | 01:02 AM
SickWS6's Avatar
Blew my rear end
i just broke my Posi and obviously i need a new one. and i dont have enough to go with a 12 bolt or 9", and i am just thinking i will pull one from a wrecked Fbody.will a rear end from a LS1 work with my car and if so do any of you have one for sale.
Thanks guys
Old Jun 27, 2006 | 01:12 AM
396D1SS's Avatar
Re: Blew my rear end
yes a ls1 rear will fit make sure its the same channel abs tho
Old Jun 27, 2006 | 01:20 AM
SickWS6's Avatar
do i need to make sure that the tcs is the same to
Old Jun 27, 2006 | 11:06 AM
ABS and TCS use the same sensors. An ABS only car (3-channel) will have the rear sensor on top of the diff housing, reading a reluctor wheel on the carrier. An ABS + TCS car (4-channel) will have dual sensors, one on the backing plate at the end of the axle housings, reading small gears on the axles, behind the hubs. If you have TCS, you have to get a rear from a TCS car. If you only have ABS, you need to get the rear from an ABS-only car.
I'll move this to "Drivetrain"..... this question has been asked at least three times in the past few days.
Old Jun 27, 2006 | 11:12 AM
SickWS6's Avatar
Thanks injuneer that makes perfect sense now.
blac94Z
Mar 2, 2015 06:03 PM
Chet1185
Feb 4, 2015 09:51 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
