TB questions
Old Jun 20, 2006 | 08:34 AM
SpeedDemon02SS's Avatar
TB questions
Can i get the same results if i port the stock TB? or should i just skip the hassel and buy a new one?
Old Jun 20, 2006 | 10:00 AM
MyShibbyZ28's Avatar
Re: TB questions
You can have people port them out to 52 or 58mm, and essentially it is the same.
Old Jun 20, 2006 | 10:02 AM
firebirdStud's Avatar
Re: TB questions
52mm is the biggest you can safely port the stocker. Yes, it works just the same. I have a ported stocker right now, and it worked awesome! But, my motor is telling me I now need a 58mm, as the dyno showed I flatlined at the top end.
Old Jun 20, 2006 | 10:07 AM
Re: TB questions
so for my mods, I would be fine with porting the stocker? where can i take it to get that done?
Old Jun 20, 2006 | 11:45 AM
TraceZ's Avatar
Re: TB questions
Guys.. This dude has a LS1... Not a lT1. The numbers and info you are giving him is for LT1s.
Old Jun 20, 2006 | 12:00 PM
Re: TB questions
thats what i thought. Cause i have seen 80mm TB's.
Old Jun 20, 2006 | 12:31 PM
teke184's Avatar
Re: TB questions
a ported stock throttle body ...on an LS1...is sufficient for most decent h/c setups with minimal sacrafice on power.
for your bolt on mods...just stick with a ported one.
only reason to upgrade these days is if you are going with a FAST 90/90 setup.
check out the vendor list, alot of the big online vendors offer ported TBs for reasonable cost.
Old Jun 20, 2006 | 01:13 PM
Re: TB questions
only mods are in the sig...future are headers, puleys, and a S/C.
how much can i get out of a ported stocker (size)? HP gains?
also, how much can you get out of the TB bypass mod?
1 more thing...what is a FAST 90/90 setup?
Old Jun 20, 2006 | 02:20 PM
Re: TB questions
I see.
what about these ones:
Old Jun 20, 2006 | 05:55 PM
teke184's Avatar
Re: TB questions
ported tb is minimal hp...nothing you'll feel hp wise, but i did feel a difference in part throttle response.
info on the bypass...even though it's for an LT1
Old Jun 20, 2006 | 06:17 PM
Re: TB questions
in the middle of my TB project. Port & polish, bypass, and bump stop.
when i went to do the bump stop, pluged in my scanner, and it is readign 100% at full throttle...do i need a different scanner?
Old Jun 21, 2006 | 12:23 AM
Re: TB questions
well, with the exception of the bump stop...i finighed the porting & polishing, as well at the coolant bypass.
gonna go for a drive in the morning cause its 2 am now.
time for some jameson and sleep.
dluna333
15
Mar 13, 2015 12:30 PM
jasonduaine
Mar 7, 2015 09:44 AM
30thZ4C
Wheels and Tires
Jan 29, 2015 06:03 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
